Noob fitment questions
Old 09-07-2015, 06:23 PM
TSX 09's Avatar
Hello all,
I found some BBS with below specs. Will this fit our cars? I don't want to do any mods. I just want to slap it on an roll.
19x8.5 5x114 18 off set front.
19x9.5 5x114 22 off set rear.
If this doesn't fit, what's the best to get on size 19 with 1 or 2 inch drop?
Old 09-07-2015, 07:18 PM
ulrblitzer's Avatar
<p>Those offsets are crazy. You'll have mad poke. I'd say 2&quot; over OEM.</p><p>I've heard people say +35 to +45 range.</p><p>If you plan to drop, plan to add camber and stance it out to.</p>
Old 09-08-2015, 10:15 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
<p>Won't fit without tire stretch and increased negative camber.</p><p>For a mild drop, 8.5&quot; +35 is a common choice of spec.</p>
Old 09-08-2015, 12:18 PM
devinv1994's Avatar
Any input on 8.5" +22mm, I'm a noob to offsets lol
Old 09-08-2015, 01:17 PM
ulrblitzer's Avatar
<p>You're still going to poke with the +22 offset. It's too aggressive unless you plan on adding some major negative camber and / \ those wheels.</p>
devinv1994 (09-08-2015)
Old 09-08-2015, 01:27 PM
xtcnrice's Avatar
<p>Will poke for sure. You'll need slightly stretched tires if you plan on lowering it enough. Might still rub even if you don't lower it much if you decide to go over a pothole hard enough or over a speedbump fast enough (basically with enough suspension travel it'll likely rub if you don't get narrow tires).</p><p>I'm on 9&quot; +30 (which is equivalent to about 8.5&quot; +24) on 225/40 tires&nbsp;and there's quite a bit of poke on a ~2&quot; drop. 8.5&quot; +22 will have about 2mm more poke than my setup.</p>
Old 09-13-2015, 02:40 AM
AcuraRolling's Avatar
best advice, lower your car to your liking, get alignment and start measuring.
if the 8.5 +22 is for the front, you will not need "major negative camber". I cant even put a number on major negative camber. naturally you will have negative camber if you lower your car as im sure we all aware, but it depends on how low you plan on going. So lets say you have the same coilovers i have and the same drop "maxed out" and no adjustable ball joints to effect camber, just natural. your camber should be somewhere around -2 or slightly closer to -3. comparing the spec you mentioned assuming its a 19" wheels running the same tire size i have (225/35) here are some figures.
2.1mm further away from the suspension strut. The outer rim will poke out 36.1mm less than 19x10 +5.
dont just go assuming the answers you receive are gospel becuase everyone is bias to their own interpretations.
36.1mm is roughly 1.5 inches. I have -5 front camber and slight pull, no poking. so its a game of measurements.
FYI, the specs you mentioned will stick out 45.7mm more than stock wheel.
my front setup was 82mm "roughly" more than stock, for the rear your fine just need good fender roll. hopefully this helps and doesn't hurt your head, I'm rambling.
Old 09-14-2015, 10:25 AM
iSeeYouTwo's Avatar
<p>I had 19x9.5 +22 all around on my previous set up and I had to roll fenders and stretch the tires.</p>
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Rcelestino93
09-23-2015 10:01 PM
Quick Reply: Noob fitment questions
