Dropped/lowered/slammed 2G TSX - Pictures, Details, Reviews
#281
Nice, you get a 2G TSX? I'd assume so since you're in this subforum
. If so, well, 18x9.5 +35 on 245s will have poke, guaranteed. If you're planning on at least moderately lowering the car (1 or 2 finger gap left), you may rub with natural camber. I'm on 18x9 +30 on 235/40s in the front, and there's maybe a little under 1cm of poke, and although it's rare I do rub once in a really long while. Should be very similar with your desired specs. But if you can pull it off, it will be a very nice meaty setup
. I wanna go 245s too
but I'm afraid I'll need probably -2.5 degrees of camber up front or so to do it.
Yes, I bought a 2010 6 speed blk/blk. It will be lowered but im thinking 245/255 might be a little too much. Im not looking to tuck tire but 1 or 2 fingers will be fine for me. I ran a 234/45 on my legacy gt wheels in the same specs and it was a baby stretch but I still had a lot of tire surface contact. Im curious about how much poke it'll have though. I'd be ok with running up to -2.5 degrees with a fender roll and slight pull. I've been basing everything off Christian Loza's TE37 setup on his TSX. He's running 18x9.5 +40
xtcnrice (03-24-2017)
97CL_NC1102 (03-26-2017)
#283
Looking for some advice.
My goal is to lower my wagon with Koni Yellow shocks by adjusting the perch. Not really looking to lower my car as it's my daily and family vehicle. However, I want to improve the handling and look. Track look.
I'm currently looking at a set of 18x9 +25 wheels and want to run a 245 or 255 tire with camber kits up frot to get some negative camber. How much will these wheels poke out? I would like to see some meat, but not look like a lowrider or someone who doesn't know what their doing.
If all else fails I will go with a +35 but I will need to change the wheel style since the wheels I like do not come in that offset. Thanks for your help.
#286
#287
VTEC just kicked in, yo!
I did recently install Ingalls front upper bjs though. My alignment is likely way out of spec now... but I didn't care much for an alignment since I was on my winter setup which I don't care much about. Still need to do a little height adjustment so I've put it off. But I put in the front upper bjs to hopefully get a tad more negative camber. Thinking -2.x degrees. The top of the wheel should "tuck in" just fine after an alignment.
With 255s, you'll very likely need a front kit.
#288
How was the installation on the upper ball joints? Hopefully to tackle my front and rear upper control arms soon after I find a quick placement for my height sensors
julius071 (03-03-2018)
#290
It will require fender work.
18x8.5 +35 to 40 with 245's is bolt-on. If you decide to cancel out rear camber, you will want to do it with a LCA kit...not a upper ball joint kit.
I have 18x8.5 +35's on 245/40 MPSS.
The following 2 users liked this post by BROlando:
EuroRspec (04-12-2017),
Teo_cleanNlean (02-22-2019)
#291
https://i.ytimg.com/vi/by3mBUF35eQ/maxresdefault.jpg I'm looking to purchase a set of vossen cv7s but I'm debating whether I should go 19x8.5 or 20x9 as those are the only specs they come in. Really leaning towards 20x9... would 20x9 be a good idea? anybody on here has any feedback, It will be my daily driver just for the spring/summer ? I'm running stock everything and not planning on doing anything to suspension anytime soon
julius071 (04-12-2017)
#293
What I learn from reading from these forums is suspension first then wheels.
#294
At risk of sounding like a broken record to many, I'm running 18x9 +30 up front on 235/40R18 Michelin PSS. Wheels poke for sure, and I'm lowered with natural camber. Not slammed by any means... but I've had a couple of rubbing "one-offs" with this setup. 1 finger-gap setup I guess. How much poke? Maybe about 1cm or so. I can take a better look this weekend when I put my wheels back on (still on winter mode
#296
Looks legit!
#297
The plan was for me to do an oil change and swap the wheels at the same time today. But... this happened
These aluminum nuts are so maleable. One of them stripped and prevented me from taking the 15mm spacer off on the front passenger side. Will have to deal with this first
#298
Sorry to hear. How were you removing that bolt impact wrench?
#299
Received 7,772 Likes
xtcnrice (04-18-2017)
#301
By hand with a standard socket wrench. Didn't ever put an impact gun on these nuts and they still strip. This one is toasted for sure, but the other ones are very close to giving as well. They are scarred all around. I got it taken off with a nut remover/extractor socket, some hammering, and a little more swearing
#302
Will be making sure to add anti-seize to avoid your mishap.
xtcnrice (07-04-2017)
#306
Very nice! Any side shots?
#308
I don't have any at the moment, but ill take some and post em up later!
18x9.5+30
radiokilla (07-19-2017)
Sheefo2k (07-19-2017)
#311
#312
#313
#315
#316
#317
#318
09 TSX w/ tech pkg in Premium White pearl.
1. Have H&R sport lowering springs
2. Drop is about 1.25"
3. Camber adjustments Front left -0.3 Front right -0.7 Rear left -2.5, rear right -2.7 .
4. No fenders mods
5. Honda Factory Performance Wheels 19"
6. Hancook Ventus Evo V12 summer tires (245/40)
These springs have OEM quality ride and there is no rubbing. Would highly recommend.
Attachment 48334
Attachment 48335
Attachment 48336
Attachment 48337
Attachment 48338
4. No fenders mods
Attachment 48334
Attachment 48335
Attachment 48336
Attachment 48337
Attachment 48338
#319
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/mvimg_20181216_164818453_38b617d4307094213b374c7164a7ecc257775b6d.jpg)
![](https://cimg8.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/mvimg_20181216_164832191_a95fab0ec5e8674b8e9d306eefca0ed0c67c940e.jpg)
2009 TSX Tech package 6 speed manual
134k miles
Koni yellows with H&R springs.
2017 TLX wheels with 225/50/18 tires, little too big for the car so it's raised just a bit. (Wearing these out to get some 235/45/18, got em for a good deal haha)
mugen_kid
11-13-2015 10:38 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
asahrts
09-04-2015 05:55 PM
