camber kit suggestions
Old 08-15-2016, 10:27 AM
icu2tsx's Avatar
I just replaced my tires. OEM spec, OEM wheels. I had some camber wear in the inside on my old tires. Car is completely stock suspensions wise. Took it in for an alignment. Camber is off,Tech said he could no adjust it. He suggests I get a rear camber kit.
Now I am been reading up on lowering kits and suspension. I read the heal toe article on the camber kits for our generation https://www.heeltoeauto.com/blogs/fo...l-joints..html So with this in mind I want to avoid aftermarket ball joints since I only need to adjust -2.1 degrees.
SPC is listing 3 pieces for TSX.
Ingall list one piece plus the ball joint
Megan list also 3 Pieces
and the ebay specials list from one to 3 pieces per wheel.
Any suggestions or experiences whether I should buy just one or do the entire 3 pieces? If I buy one, which one will get me the -+ 3 adjustment.
Old 08-15-2016, 11:27 AM
Received 16,267 Likes on 11,974 Posts
the tire wear came from your toe being out.
look at the before specs. TOE is totally OUT!
oh chit, rear toe is STILL OUT!!
go back to alignment shop and get TOE to ZERO
xtcnrice (08-15-2016)
Old 08-15-2016, 02:14 PM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Yep.. some shops will be lazy and take advantage of those who don't have much experience with the details in an alignment. They can do better than this with the toe. Go back and get them to redo it if you can, and try to get it done without paying a cent more.
Minus 2 rear camber won't do much hurt IMO. As justnspace said, zero out the toe if wear is your concern. I suggest not bothering with a camber kit until/unless you lower the car.
Old 08-15-2016, 02:17 PM
I believe up to -1.7 through -1.8 camber is still in spec.
icu2tsx (08-16-2016)
Old 08-15-2016, 04:59 PM
BROlando's Avatar
Received 1,193 Likes on 897 Posts
positive means toed IN. The car should have a little rear toe in to make the tires wear evenly and for stability on the highway.
I would not 0 out rear toe. Front...sure. But not rear.
Leave about 0.1 degree IN (positive) toe, as per spec.
My concern is the ridiculously uneven rear toe. That car is going to wander to the right.
The following 3 users liked this post by BROlando:
icu2tsx (08-16-2016), justnspace (08-16-2016), xtcnrice (08-16-2016)
Old 08-16-2016, 08:29 AM
icu2tsx's Avatar
Yeah toe was out of spec
They threw my car on the alignment rack before closing time and less then 18 min they were done. I've had lowered cars and they tend to take longer in my past experience. Tech told me he could not adjust anymore and he suggested I get a camber kit ($408 estimate) to correct the rears. I question why an oem suspension would need a camber kit. He gave me some bs about being old and tear and wear on the suspension and that he could not adjust the rears. I question the before and after spread sheet as well. He said that once I had the camber kit he could adjust the toe too.
I told him I would get my own kit but I was still confuse as too why I needed a kit for oem spec. He then said since he could not adjust the rear he was only going to charge me for the fronts ($50)
Since I just spend $600 on tires from Costco I want this tires to last so I started looking into camber kit. But know I feel like this the shop ( Le schwab) try to pull a fast one on me.
Old 08-16-2016, 08:53 AM
xtcnrice's Avatar
Thanks for always sharing great information for guys like me!
Old 08-16-2016, 08:55 AM
toe is adjustable. you dont need the camber kit to adjust toe.
have them re-do alignment.
Old 08-16-2016, 08:59 AM
icu2tsx's Avatar
Thanks for this info.
anywhere I can find acceptable specs. Might bite the bullet and take it to stealership for a proper alignment.
So far it drives pretty straight.
Old 08-16-2016, 09:02 AM
icu2tsx's Avatar
yeah another alignment is going to happen for sure. Just not sure If I trust the same location.
Old 08-16-2016, 10:48 AM
BROlando's Avatar
Go back to the same place. No point in paying for an alignment again. Try to make it there before closing time.
Old 08-16-2016, 10:57 AM
BROlando's Avatar
Factory specs should be in the owner's manual.
Ideally, you'd want the fronts to be either very very slightly toed IN...or at 0.
The rears, you'd want evenly toed in to about 0.08 to 0.1 degrees per side.
no problem!
yes. this is correct. the car has factory provisions for toe.
the camber is off a bit...which is likely due to some normal suspension wear. but it won't cause much issue if the toe is within spec.
quanaman
08-17-2016 11:38 AM
edmonb
08-15-2016 08:01 AM
94eg!
06-01-2016 06:35 PM
Rob_TL
20
05-25-2016 01:43 AM
khaos337
04-29-2016 08:20 AM
Quick Reply: camber kit suggestions
