BACK to the TSX!!!
2021 RDX A SPEC
BACK to the TSX!!!
ok.. i'm picking up my 2010 pwp v6 tech monday evening.
Traded in my beautiful beloved 07 TL navi.
question:
the TSX comes with 18" rims/tires. I equipped my TL with 16" 205/60/16 winter tires and it accomodates them perfectly. Can i put these same rim/tires onto the TSX as well JUST for the winter? any real 'offset' issues?
I think the TSX is +55 while the 16" wheels for my winters are +45.
the curb weight seems to be almost the same as the TL navi.
btw, this is my 4th TSX. see cars below:
question:
Welcome!! I get the feeling that after the mazda you really started to like your acuras lol. I am also in the Vancouver area so mabye I will see you around!
Congrats and welcome. Are you located in Metro Vancouver?
The European Accord has 16 x 6.5" rim w/205/60/16 tires on their ES (2.0L 4cylinder model-CU1), so they should work.
Do check the load rating on tires to make sure it can handle the weight.
The TSX V6 (CU4) uses 18 x 8" rims, check for clearance with the 16". Because of the offset and reduced width on the smaller rim, they would appear more tucked in than the stock 18".
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
nuldabz
09-03-2015 05:49 PM
