Adjustable front control arms??
Old Sep 30, 2012 | 11:20 AM
Asian Candy's Avatar
After lowering, my camber is off in the front. But only on passengers side. So I bought a sector adjustable ball joints, but for the life of me cannot press out the old ball joints. Went so far as to take off the upper arm, held one side in a vice and tried pressing it out. No luck.
I'm crazy frustrated.
So I decided to just replace the entire control arm with an adjustable one. Can't find any for the 2nd gen. Only 1st gen.
Does anybodyknow who, if anyone, makes adjustable front upper control arms for our cars?
Old Oct 2, 2012 | 04:29 PM
jgarcia19's Avatar
im not sure if they make adjustable control arms for the 2G TSX, but i was barely able to remove mine with a ball joint press that i rented from autozone. it was a PITA and took a ton of patients. i had a friend hold the bar while i kept turning. good luck!
Old Oct 4, 2012 | 04:52 PM
Tannis's Avatar
http://www.ebay.com/sch/i.html?_saca...ries&Model=TSX
Don't know if this is exactly what you need. But I'm sure you'll find something useful.
Old Oct 4, 2012 | 05:49 PM
tobwac's Avatar
^those are only for the rear and some of them are not for CU2 model i havent seen any company making control arms for front yet
Old Oct 4, 2012 | 09:22 PM
Thanks Tannis.
I looked all through eBay and a few other sites from google search and all are for first gen.
Came across a set of OEM arms without the ball joints. May have to go that route.
Old Oct 7, 2012 | 02:42 PM
Tannis's Avatar
Ah. My bad bro. I re-read your opening post and I think I misunderstood or missed the word "front" in there. Hopefully you got a fix for it. I'm about to pull the trigger on a set of coil overs and the rear camber kit is on the way. I'm just trying to figure out the front now. You said the ball joints wouldn't come out but you have the adjustables, right? Are the adjustable joints enough to correct for the camber? I know the SPC joints only adjust to 1.5 degrees.
Old Oct 7, 2012 | 08:28 PM
SPC ball joints are what I have. Camber is only off on passenger side for some reason. It's -.9. Driver side is fine at -.1
I know some people on this forum have changed out theirs, but I have no idea how.
Old Oct 8, 2012 | 04:08 PM
Tannis's Avatar
I think you need a real hydraulic press from a garage. You could alway go and see if one of the smaller tuner shops will press em out for you. theyd probably do it for $20.
Old Oct 9, 2012 | 10:04 PM
asdcxvbnmjersey's Avatar
4th Gear
Printed Official NFL Carolina Panthers Jersey circuit board Model
(Dealer, Companies)Rural ( space ) TaiwanCategory . Devices : Computer hardware : MotherboardsContact | Hyperlink to Substance | A whole lot more Treatments In that time CompanyImagesClick though logo and see bigger period mark .
Blade plating is manufactured after a rout steps 's implemented prior to a metallization inside the circuits features of the actual pcb and it is also occasions recognised as "plated rout". The style preferences for implementing fractional treatments will jhjvghg780kjbjhbg most certainly be reliant upon necessity for product or service benefits is bordered by in each surfboard, as big as currently the boards, additionally regardless of if the pieces of wood are developed inside of a multi-up wide variety.
PCB Model Area Plating On a Holds the road Utilizing Immersion Silver precious metal Completely finish
4 . The surface by having Nike NFL Throwback Jerseys concentration jewelry full.
; Plating on top of the banks.
Features:
> Wedding plating to plating leftovers on isn't stable about Official NFL Cincinnati Bengals Jersey the body.
Is 3~6 business days to obtain prototypes, of model production.
TagsEdge Plating, Printed circuit board Magic size, Red peelable conceal, Enterprise Get on, Promotional Nike Steelers Men Jerseys World, PCB Effects Plating, Printed circuit board Manufacture
Please note: Submitters concerning products seo backlinks are actually especially the culprit for or perhaps video. PRLog are not to be regarded accountable for the type of items in this item auction or sale listings. Ebook Addiction
marcelft
Jul 10, 2018 06:17 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
gqdabien
Sep 8, 2015 11:41 PM
08 NBP TL
Sep 8, 2015 08:49 PM
nuldabz
Sep 3, 2015 05:49 PM
