VSA and ABS lights went out after jump starting the car
VSA and ABS lights went on after jump starting the car
I have a 2011. Any ideas on how to clear this out?
TSX AMG Type //M i-VVT
I had that problem but it cleared as soon as i started moving..
Thee great defconskylude has returned, we are not worthy!
My noob advice is disconnecting the battery didn't work? Lol.
The following 2 users liked this post by xtcnrice:
rawger (05-31-2014),
themalcman10 (04-23-2023)
Itz JDM y0!
This actually just happened to me like 30mins ago after I switched out the front map lights to LEDs. In the manual on pg.283 it says if the interior lights come on fine it might be a blown fuse, so I'd check the fuse box.
Everyday I'm rofling
I got jumped once and no problems here.
LOL that's epic. That man gave no fucks. Do you know exactly where that's from?
Too good for the other TSX's? I understand man.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
ROTAREDOM
i have 2 kids now and im done with my TSX.
im all into firearms now
i got a new mini mill and will be designing/fabricating my own rifle chassis for .22 long rifles
so im learning some basic machining and solidworks when i convert it into CNC
![](https://farm4.staticflickr.com/3736/14253662752_1652800406_c.jpg)
ROTAREDOM
You should learn MasterCAM.. It's supposed to be pretty good for amateurs. If you call MasterCAM and tell them you are a student they will send you a free copy thats good for a year. That'll give you the basics for programming your CNC machine to cut what you have designed in SW. It has a whole SW app. that brings in a .STEP file and you can select edges/profiles and faces. The biggest thing is know how big the cutter is and areas that may lead you to crash the machine. It doesn't really warn you if you've entered code that may cause your machine to crash. The virtual simulation is sub-par.
Also, since you fabricate a lot, you're probably aware that people are rapid prototyping metal now too. ProtoLabs can do a bunch of metals just from a simple SW file. ANNND they only 3 day lead times. Pretty cool!
VTEC just kicked in, yo!
ssjoeboe9 (06-03-2014)
