valve is fixable/replaceable??
Old Feb 6, 2018 | 10:33 PM
Squinto's Avatar
the valve for my 2010 tsx is broken and I was wondering if anyone knows any cheap ways to fix it because I heard it is very expensive.
Old Feb 7, 2018 | 06:28 AM
are you speaking about the over head engine valves?
we simply need more information on what you did/how the valves were damaged.
Do you have the 4 cylinder 6MT? Did you over-rev/perform the money shift?
Did you suck up water?
How do you know the valves in the head are damaged?
we simply need to know everything that happened/ How you came to this conclusion
Old Feb 7, 2018 | 07:54 AM
cu2wagon's Avatar
But the answer is probably "no".
If whut ever it is what is broken is supposed to be an expensive fix... There is likely not a cheap fix.
Well, maybe there is a cheap fix, but it's probably not a good fix; ala, "turn up the radio".
But yeah... What "valve"?
Old Feb 7, 2018 | 09:46 AM
losiglow's Avatar
Maybe get a used cylinder head from a salvage dealer or eBay. A coworker of mine bent some valves when the timing belt snapped on his 4 cylinder '02 accord and we just put on a used head. It's not a simple job but it was only about $150 with the head and gasket. I'd imagine a mechanic would charge 4 hours of labor or so? Maybe more. It took us about 6. We put on the new belt, cleaned up the piston heads and a bunch of other things while we were at it. New coolant, oil, adjusted valves on the used head. Runs like a kitten now
Old Feb 7, 2018 | 09:48 AM
That's what I did as well.
I found some Acura heads that fit my car and installed them myself
Old Feb 7, 2018 | 10:32 AM
Squinto's Avatar
I have an automatic. a mechanic just told me that the timing chain is fucked and thats why my car isn't starting. he also mentioned I had metal in my oil so idk if that info will help. the valves are ruined that I would have to replace it or just buy a new engine.
Old Feb 7, 2018 | 10:33 AM
Maybe he's talking about his PCV valve
Old Feb 7, 2018 | 10:34 AM
nope.. never mind. How many miles? What did you do? You gotta learn to post a bunch of information in your thread if you want substantial and constructive advice, not just "my shit broke, how fix yo?"
Old Feb 7, 2018 | 10:38 AM
cu2wagon's Avatar
I was wondering if it was maybe the heater mixer valve.
Like you talk. More information good. Make fix words better time.
Old Feb 7, 2018 | 11:13 AM
losiglow's Avatar
dcmodels
1G RDX DIY & FAQ
24
Nov 25, 2020 03:20 PM
dcmodels
1G RDX DIY & FAQ
Mar 24, 2018 08:35 PM
zain
Jun 3, 2008 02:38 PM
UNCTYPE-S
Jan 5, 2004 11:44 AM
jjpark
Jan 3, 2004 05:54 AM
