TSX Cold Start Grinding Noise
Old Oct 25, 2013 | 04:04 PM
mrjohn90's Avatar
Has anyone else experienced this problem before? I'm also out of warranty
Old Oct 25, 2013 | 06:08 PM
ATLBuckeye's Avatar
It could be your VTC actuator. Does it happen all the time? Are you under 70k miles?
There is a known problem with VTC actuators. Faulty units will drain of oil when the car is off, and thus the grinding. If you happen to be under 70k for powertrain a dealer will replace it free of charge.
Old Oct 25, 2013 | 08:23 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
Mine does this occasionally. It is the VTC actuator i think. There is a TSB for this, but my dealer refuses to do it for me.
Old Oct 26, 2013 | 08:29 AM
mtdew456's Avatar
I had this problem for two years. Every time the car would be at the dealer I would leave it overnight before service and they would start it in the morning with no noise. One time the car was in for service the car finally made the grinding noise on cold start. Dealer replaced the VTC actuator and I have had no problems since.
Old Oct 26, 2013 | 09:09 PM
boki_cu2's Avatar
g35 have exact same thing, its more common with them.
get dealership to check out asap
Old Oct 26, 2013 | 09:45 PM
mrjohn90's Avatar
Thanks for the input guys! Unfortunately I'm at 86,000 miles
Old Oct 27, 2013 | 06:30 AM
boki_cu2's Avatar
Does it do it after oil change with fresh oil or all the time?
Old Oct 27, 2013 | 11:45 AM
ESHBG's Avatar
I have the same EXACT thing going on with my car! I'm still within the power train warranty and it will be due for its annual state inspection soon, so I will mention it when it is at the dealership next.
Old Oct 28, 2013 | 11:25 PM
caeavesrsx-s's Avatar
VTC actuator for sure. I just replaced mine and it went away. Ordered the part online and had the local honda guru install it. Problem solved.
Old Oct 29, 2013 | 04:22 PM
wraith's Avatar
Same here However, It's doing it again. I had the ATC actuator replaced at 44k miles (under warranty) and it's doing the same thing again at 115k miles. SMH
Old Oct 29, 2013 | 06:20 PM
kostantinos's Avatar
dealer would not replace it on my 2011 until they heard it, and it would never do it while it was there.
my 2013 hasnt done it thank God
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
jblessing
Aug 8, 2018 09:43 PM
dlknight
Sep 3, 2015 07:54 PM
