Tire Pressure
Old Jun 19, 2008 | 03:03 PM
jdimase821's Avatar
Tire Pressure
Anyone know what the PSI should be set at? I got in the car this morning and for the second day in a row the TPMS light was on..... all tires were at 26psi. Doesnt seem right. I just got the car 4 days ago.
My previous cars didnt have TPMS and I usually kept it at 34psi
Old Jun 19, 2008 | 03:32 PM
JTso's Avatar
The tire pressure spec should be on the driver side door jam.
Old Jun 19, 2008 | 03:35 PM
jdimase821's Avatar
I am at work and it just came to mind. I'll check it when I get home as the car doesnt come to work with me.
Old Jun 19, 2008 | 03:58 PM
ill45's Avatar
i believe its around 34psi off the top of my head without checking.
Old Jun 19, 2008 | 04:25 PM
jlukja's Avatar
My 04 recommended settings are 32PSI front and 30PSI rear. I acutally overinflate to 35F/33R. The tire sidewall, I believe, says 41PSI max. I'm relatively sure that the specs should be the same for 04-08 since the vehicle weight and OEM tires haven't changed.
I do have a follow up question. What should be the proper inflation if you put on a different brand of tire? If the new tire has different thickness sidewalls, or has a different load rating, would the door jamb PSI recommendations still apply? Or would you go with (32PSI/41PSI) 78% of the sidewall maximum PSI? I'd be interested in hearing you guy's thoughts on this.
Old Jun 19, 2008 | 04:31 PM
JTso's Avatar
Some info here. http://www.tirerack.com/tires/tirete....jsp?techid=72
There are additional charts at the bottom for other tire ratings.
The complete tire tech articles. http://www.tirerack.com/tires/tiretech/tiretech.jsp
Old Jun 19, 2008 | 04:52 PM
jlukja's Avatar
^^ good read. Thanks J
Old Jun 19, 2008 | 05:29 PM
thunderbt3's Avatar
33 PSI all around cold. As for warm, I've seen 38F/36R.
Old Jun 19, 2008 | 05:59 PM
Mokos23's Avatar
warm i have mine at 40/39.
Old Jun 24, 2008 | 08:35 PM
losothefatso's Avatar
I hit the curb once and it feels like my right rear is always lower by a lot, but on the display its usually only 1psi lower than all the others. Any suggestions on what to do? [ sorry if im stealing a thread]
Old Jun 24, 2008 | 08:42 PM
EuroR08's Avatar
wow i run mine at 29/31 warm - but im going for some sort of traction rather than good gas mileage i guess
Old Jun 25, 2008 | 11:58 AM
Catman's Avatar
The manual says 33psi cold.
Old Jun 25, 2008 | 12:35 PM
jdimase821's Avatar
yeah when i got home the night i posted this thread i checked. They are all eqaul at 34psi now.
Old Jun 28, 2008 | 01:36 PM
[R]isque''s Avatar
'08 CU2 Honda Accord Euro
Pump the tire up!!!
Old Jun 29, 2008 | 02:26 AM
Hmm It usually runs around 34/33 depending what time of the day it is. Since its summer now I'm not sure how much to pump it up or it's still necessary.
Old Jul 21, 2008 | 01:52 PM
The Dark Knight's Avatar
my car came with 35psi cold
it runs at around 37psi hot
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
mugen_kid
Nov 13, 2015 10:38 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
HeloDown
Sep 8, 2015 06:51 PM
