Noisey Engine is scaring me!
Old Oct 3, 2013 | 07:30 PM
Jeffreysachs's Avatar
4th Gear
Hey Guys.
Just hit 55k miles on my 2010 automatic. It seemed like it was making a little bit a noise and it was about 6k since my last oil change so I figured I would change it and see if it helped at all.
I put in 5-20w Penzoil Platinum filled it between the dots and started the car. Didnt seem to do anything to the sound so it wasnt low/old oil related.
But today I decided to open the hood and listen closer. It is much louder under the hood then in the driver seat. Driver seat isnt noticeable at all with music on but I constantly listen for sounds in my car so I began to notice it.
Video is on youtube here. http://www.youtube.com/watch?v=dtdTI...ature=youtu.be
Any ideas? I was thinking it was just belt related and the belt makes a scratchy type of sound. But there is the clickier sound coming from the opposite side of the belt.
I've read around and I've heard timing belt, torque converter, and normal. If it is normal I wonder if the previous owner / dealer wasnt using 5w-20 and was using something thicker that muddled the sound (read that somewhere too)
Help!
Thanks all.
Old Oct 4, 2013 | 12:12 AM
BaoZZeR's Avatar
Not sure if its just me but there's no sound in that video.
Anyways my friend's engine made a really loud noise and we didn't know what it was but it turned out to be the power steering fluid so check there.
Old Oct 4, 2013 | 05:11 AM
4th Gear
Thanks. I assume you mean nothing sounding out of the ordinary to you? Not that the video has no sound.
The engine seems a little "scratchier" after the oil change is all. The oil is at the top dot so I don't want that to be the issue.
Temps are ok, no lights on in the dash. I assume if there was a serious issue with the oil a light would come on before damaging anything.
Old Oct 4, 2013 | 05:30 AM
komplexZ's Avatar
yea let us know how the power steering fluid looks...
Old Oct 4, 2013 | 10:33 AM
iCrap's Avatar
TSX AMG Type //M i-VVT
Sounds EXACTLY like mine did
it went away on its own though. I still have no idea what the noise was. Dealer said it was normal operation....
Old Oct 4, 2013 | 06:15 PM
Skwatoe's Avatar
Will chop for food...
Mine sounded just like that, but it was accompanied with the CEL and VSA Warning light. It turned out I had slack in the timing chain. I was at 80,000 miles.
Old Oct 4, 2013 | 06:42 PM
JDMaccord3.5's Avatar
I believe all Honda/Acuras 4 cyl make this noise.... my 09 accord used to make the same sound
Old Oct 4, 2013 | 08:18 PM
26Shaun's Avatar
My 2009 has pretty much always sounded this way. I bought it brand new and it has over 90k miles on it now.
Old Oct 5, 2013 | 01:19 PM
4th Gear
TSX Ticking noise - YouTube
Thanks man. It does sound the same... I'm not going to worry about it much. Just going to have the dealer check everything out at 60k miles anyways since it seems to be a big maintenance marker. Tranny fluid, timing, etc. Maybe I'l bring it a bit earlier.
From what I read, it is possible the dealership put thicker oil in to reduce the noise so I would buy it. But now that i put proper 5w-20 in it is a little louder.
Oh and NO Thanks to power steering fluid jokers! I might be a paranoid car owner but not falling for that one. I've been on these forums a lot since owning the my TSX.
Old Oct 11, 2013 | 11:16 PM
Adam Rutledge's Avatar
I didn't know acura imported the cu2 diesel model :-p :-) :-)
Old Oct 12, 2013 | 01:48 AM
blutsx's Avatar
Mine has always pretty much sounded like that too, but its only noticeable with the hood open and up-close.
Old Oct 16, 2013 | 02:41 PM
HondoGermany's Avatar
Diesel is CU3, Tourer as Diesel is CW3
Old Oct 20, 2013 | 07:35 PM
MyWhiteGirl's Avatar
i have the same noise. I mostly hear it when the car is cold. :-(
Old Nov 18, 2013 | 03:32 PM
26Shaun's Avatar
Just a follow-up to this thread. I replaced my idler pulley, serpentine belt, and tensioner assembly and the noise from my engine bay has been reduced significantly.
Old Nov 18, 2013 | 03:36 PM
gplayer's Avatar
Just sounds like lifter tick to me.. no real problems there.
Old Jan 5, 2014 | 09:11 PM
CapNcook's Avatar
Mine sounds pretty similar, I wouldn't worry about it
Old Jan 24, 2014 | 10:11 AM
ojasdatt's Avatar
2009 TSX
its normal
Old Sep 7, 2014 | 01:21 AM
olio13's Avatar
3rd Gear
my 2010 sounds similar, loud tappets and some noise coming from air intake.
is this normal? I have 79km
SidhuSaaB
May 30, 2020 12:40 AM
spoiler900
Oct 10, 2015 06:48 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
