Need to replace the engine in my 09, need to verify a few things
Old Jun 7, 2016 | 11:02 AM
C2CuSn07 TL's Avatar
Hello guys. Looooong story short we need to put a different engine into the TSX. We were hoping to trade the car in but this came up, so we decided to put in a different engine before trading it. Dealer wants 8k to swap in a short block, so that's not happening. Looking for low milage engines, I have been told the 09-10 engines run 5w20 and the 2011-2012 run 0w-20 and putting a 2012 into the car could cause issues. Can anyone verify this for me?
Jesse
Old Jun 7, 2016 | 11:06 AM
why is the short block done?
and its the same engine, just acura chose a different weight of oil to be in compliance of CAFE (Corporate Average Fuel Economy)
Old Jun 7, 2016 | 11:07 AM
Acura DID the SAME exact thing for the TLs.
My TL's oil cap says 5w-30.
my Buddy's oil caps says 5w-20
even tho its the same exact engine
C'mon man, you have a built TL!!!!! lol
Old Jun 7, 2016 | 11:09 AM
and you can always head to Car-Part.com--Used Auto Parts Market
enter in the required info; make, model, year, what part you need and area code.
and the results will spit out junk yards that are close to you with the part you need.
I bought a used TL engine this way.
Old Jun 7, 2016 | 11:32 AM
Car failed the oil consumption test at 17qts of used oil over 6k miles. When they went to take the engine down they discovered the engine was not original and came from a totaled TSX. So it is not covered by Acura's recall. Now it's my bill. I didn't hesitate to run the 2012 in the 2009 until an Acura Mastertech at the dealer mentioned the oil weight discrepancy. I was like, sh1t! So I am just double/triple checking before we get in there and realize they are different.
Old Jun 7, 2016 | 11:37 AM
I used Car-Part.com--Used Auto Parts Market and I bought a used TL engine from one of the junk yards that was listed in the results...
i bought the engine for $650.
Do the same exact thing for the TSX.
Browse car-part.com until you find a used engine that meets your requirements near you
Old Jun 7, 2016 | 02:02 PM
Thank you sir. I found a 2013 engine as well. Checking to see if they plug and play into our cars or not
Old Jun 7, 2016 | 02:08 PM
ssjoeboe9's Avatar
ROTAREDOM
Mechanically, I do not know of any differences. But the ECU's between the two years are different (software, protocol etc..) I don't know if you would throw any errors because of this. I guess you could also replace the ECM/PCM with 2012 and it should be ok.
Old Jun 7, 2016 | 03:34 PM
ceb's Avatar
ceb
and then there are the wiring issues between tech and non-tech.
The easiest swap would be the same year and tech level. Swapping ECUs will always cause issues.
But - if the problem is merely oil consumption and you are trading the car then why swap engines? Just disclose the issue and take the small hit on resale.
Old Jun 7, 2016 | 05:11 PM
I used the link justnspace provided and for the 2009 they offered all of the way up to 2014. Justin can you chime in here before I pay this guy for a 2013 with 30k on it.
Old Jun 7, 2016 | 06:08 PM
Okay everything I am reading and cross referencing says 09-14 are totally interchangeable. Imma pull he trigger and keep you guys posted
Old Jun 8, 2016 | 01:15 PM
t3hhcaptain's Avatar
Why not just do the TSB steps? Seems like the least expensive option?
gavriil
Aug 20, 2025 04:43 PM
Black Tire
Dec 18, 2017 08:15 AM
GK83
Sep 13, 2014 12:48 AM
