Need help to identify this Bolt.NEVER seen before
Old Aug 13, 2019 | 07:44 PM
Quang_7535's Avatar
7th Gear
please help me identify this bolt. i'm trying to replace my upper transmission mount, came across this bolt. its going through the bracket into the mount. does anyone know what kind of bolt is it or what kind of socket use to remove it?.
Old Aug 13, 2019 | 08:19 PM
https://www.oemacuraparts.com/v-2012...gine-mounts-at
Which mount are you referring to?
Old Aug 13, 2019 | 08:23 PM
To answer your other question, i believe it's external or female or inverted torx
https://www.homedepot.com/p/Husky-1-...13PC/206031060
Old Aug 13, 2019 | 08:43 PM
Quang_7535's Avatar
7th Gear
im referring to the upper transmission mount on an 09 tsx.. and i thought it was an e torx bolt but my friends he work on car and he said its not. idk. please help
Old Aug 13, 2019 | 08:50 PM
manual or auto?
Old Aug 13, 2019 | 08:59 PM
Quang_7535's Avatar
7th Gear
it's automatic tranny....you were right man!! it's an external torx plus socket that i needed. Thanks alot, much appreciated. now i have to by a whole set cause i don't know the exact size lol
Old Aug 14, 2019 | 09:37 AM
ksawant's Avatar
You do not need to remove this bold to replace transmission mount. Just support your transmission with jack and then unscrew remaining 6 bolts. 3 are on transmission and 3 on the car frame. It is just 20 mins replacement job.
Old Aug 14, 2019 | 09:38 AM
ksawant's Avatar
Forgot to tell you. New OEM transmission mount comes with the bracket. If you are going aftermarket then not sure.
Old Aug 14, 2019 | 07:23 PM
Quang_7535's Avatar
7th Gear
yea i saw the same diagram on all data that my friend sent me. but i didn't know if the bracket was going to be in the way of the bolt going into the frame closest to the cabin. And aftermarket does not come with bracket. But much appreciated your input. Thanks
Old Sep 8, 2020 | 01:51 PM
Junzmarley's Avatar
5th Gear
Did you figure out what size bolt that was ?
Old Dec 12, 2021 | 02:22 PM
Xavier Castillo Lopez's Avatar
can someone help me identify this bolt please. It's circled in red.
victus1
Apr 13, 2016 12:09 PM
mikebikelife
Jan 23, 2014 03:42 PM
sauceja
Apr 7, 2013 10:01 AM
Bham03TLs
Nov 13, 2010 02:38 PM
StonedCL
Jan 24, 2009 11:56 AM
