Lamin X Film
Lamin X Film
Just got a damn chip in my foglights and going to be replacing the foglight. From expeirance from people that have used Lamin X to protect their fogs, what would you recommend to get in thickness, 20 mil or 40 mil?
40 mil seems a little thick and im worried for when I cut it out of the sheet and install it since the 09 TSX fogs have a little bit of a curve that I would be able to get it on right without creases or what not.
Would 20mil be good enough to protect from rocks and loose gravel and prevent it from chipping/cracking the lense?
Hmmmm. I bought LaminX for my ilx fogs and never found any options for different thickness.
I searched your car and found not indication of thickness still...
http://www.lamin-x.com/Acura-TSX-Sed...rs-p/ac115.htm
That link is to some precut laminx fog covers for the 09 tsx. You just pick the color you want, not thickness.
This is what I did, except I purchased from Amazon since I have Amazon Prime 2 day shipping. I never picked the thickness just the color. Precut to my size and fit pretty good. They were VERY flexible so I dont think you will have any issues getting it to stick to a curve or bend.
How is the precut ones working out for you? How long have you had them for?
Precut, 15 bucks.
Seems like that's the best bet unless the sheet is cheaper.
I have a rock chip or two on the painted surface. I applied laminx within the first couple months of ownership. I've had them for over a year and a half. Fog lights still look like the day I picked the car up.
i have done it with the fog in my hand which is easier. especially on the 11+ where the lens is smaller than the opening. but on my current ones I, the TRS led fogs, i bought a small sheet of the 40mil and cut my own circle. I was lazy and did this with the fogs mounted. to cut the film, first I measured the opening and figured a bit larger, then i used the same caliper to draw a circle on the plastic while protecting where the point rested. cut with good scissor.
the laminx precut is just big enough to do with bumper on.
wet or dry install?
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
EE4Life
Sep 11, 2015 10:13 PM
