Help! 2012 TSX wont start
I just got a ride back from a friends house because my car wouldn't start. All of the lights work and everything is completely normal until I twist the key from the II position to try and start it. There's just one click and then nothing....It's not the battery. Same thing happened when I tried jumping it. I'd appreciate any advice you may have
Ishb00 (10-14-2013)
Same thing happened to me about 2 weeks ago. My lights would come on radio worked... But my battery didn't have enough power to crank the car up. I replaced my battery and the car worked like a charm.
I'm almost certain its the starter. I've heard that replacing the brushes can sometimes do the trick? Also, do you know if the starter is behind the intake manifold like on the 1st generation tsx?
it's a car-drive it
It's kinda a unique situation. Long story short, the car is no longer under warranty so I can't take it to the dealer :/. The first thing I looked at was the battery. Nothing changed when I tried jumping it. I had it tested just to make sure and it was right at 12.5 volts. Thanks for the replies. Looks like I'm changing the starter. Has anyone removed the starter on the second gen TSX without taking off the intake manifold?
Before you swap the starter you should make sure the starter relay is getting power when key is in start. Check the neutral safety/ transmission range sensor too if no power to the relay.
cycdaniel
12-17-2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
IndycarFaster
09-11-2015 02:52 PM
