Fixing Drl harness plug
My Drl harness ground wire pulled out when i was adjusting it, is there a way to fix it or somewhere I could order just
the hardness wire.
the hardness wire.
Not to my knowledge. That's why the repair procedure is necessary. Only alternative is to find a junk car and cut connector w/ wire ends to splice to your wiring. Try car-part.com to locate a donor vehicle near your zip code.
good luck
good luck
Soupi's car is a junk car. Can he be his own donor?
Received 7,772 Likes
I'm not entirely familiar with which plug you're talking about. Is it the DRL/High-Beam plug that goes to the bulb?
If so, isn't that just a standard 9005 socket? Should be on ebay, amazon, NAPA, etc. for a generic connector for a few dollars.
Yes, just need the blue part of the plug, it seems like 9005 socket didnt match what i was looking for.
DevtypeS
10-11-2017 11:55 AM
jjk61083
01-23-2016 02:30 PM
mattyacura
01-23-2016 08:02 AM
CryingMidget
12-27-2015 11:02 PM
dms123
12-26-2015 05:16 PM
