Fixing Drl harness plug
Old Dec 27, 2015 | 11:21 AM
soupi's Avatar
My Drl harness ground wire pulled out when i was adjusting it, is there a way to fix it or somewhere I could order just
the hardness wire.
Old Dec 27, 2015 | 11:52 AM
TexasHonda's Avatar
It can be repaired. See following video.
good luck
Old Jan 5, 2016 | 09:55 AM
soupi's Avatar
thank for the video....
is there a part number where i can just buy only the blue harness and the wires that come with it?
Old Jan 6, 2016 | 11:23 AM
TexasHonda's Avatar
Not to my knowledge. That's why the repair procedure is necessary. Only alternative is to find a junk car and cut connector w/ wire ends to splice to your wiring. Try car-part.com to locate a donor vehicle near your zip code.
good luck
Old Jan 6, 2016 | 02:16 PM
ceb's Avatar
ceb
good luck
Soupi's car is a junk car. Can he be his own donor?
Old Jan 7, 2016 | 09:13 AM
icu2tsx's Avatar
^ lulz
Old Jan 7, 2016 | 10:51 PM
cu2wagon's Avatar
I'm not entirely familiar with which plug you're talking about. Is it the DRL/High-Beam plug that goes to the bulb?
If so, isn't that just a standard 9005 socket? Should be on ebay, amazon, NAPA, etc. for a generic connector for a few dollars.
Old Jan 25, 2016 | 09:26 AM
soupi's Avatar
Yes, just need the blue part of the plug, it seems like 9005 socket didnt match what i was looking for.
DevtypeS
Oct 11, 2017 11:55 AM
jjk61083
Jan 23, 2016 02:30 PM
mattyacura
Jan 23, 2016 08:02 AM
CryingMidget
Dec 27, 2015 11:02 PM
dms123
Dec 26, 2015 05:16 PM
