Error Codes on Dash
Error Codes on Dash
I have a 9 yr old 2009 Acura TSX with 96,700 miles.I have been the sole owner.
Just yesterday, I start my car and I have my Dash lights up.
I have a CHECK EMISSIONS LIGHT on.
I have a CHECK VSA LIGHT on with TRIANGLE.
So I get the codes scanned to see what errors pop up.
83-1 Engine Control Module (ECM), Powertrain Control Module (PCM) Relation Malfunction
62-1 Battery High Voltage (I just replaced my 2 year old battery the day before with a brand new one???)
61-1 Battery Voltage Malfunction (again I have a brand new battery)
P0341 - Camshaft Position Sensor A, Circuit Range Performance, B1
Any advice before i head to Acura Dealership? During my last oil change in Feb, I was told my Timing Belt was Stretched. I believe that is related to the P0341 code.
(PS. I am currently going through my 1000 mile oil consumption test for the Piston Ring TSB/Burning Oil Issue...I have driven 400 miles left to go before they will determine any repairs, Not sure if this is related.)
Thanks in advance.
Thanks in advance.
@MrTee12 - did you found what was the problem?
I got similar issues today, on my 2009 TSX.
In addition to EMISSIONS and VSA lights, engine cranks for about 5 sec before it starts and after about 30 sec I get WATER TEMP HOT.
It's all in idle mode and I engine cooling fan stays still
I took my car back after my 2nd 1,000 mile oil consumption test. They said that everything looked normal and the oil was exactly where it should be. My car oil level was at 60%.
I spoke to a Service Advisor about my issues. I will be making another appointment soon to have these issues checked further. I will keep you updated.
GoodDay I did this with my 2009 Acura TL that has 153k mileage and I undo the battery and pull out the ECM fuse it went after I did that but it came back now am assuming I have a bad computer now I just need help from someone that knows the location of the ECM and am assuming it’s under the dashboard of the car can anyone help me ?
buy, borrow, or pay someone to use their bi-directional scan tool.
the scan tool will tell you if there is anything going wrong with the ECM/PCM/BCM/DTC errors.
if this means taking it to the dealer, so be it...because then you will know what exactly is going on...only a bi-directional scan tool can figure this out
alright thanks I understand but still would like to know the location of the ECM if some other at home remedy works
^that's the thing tho....
the scan tool will tell you exactly what is broken.
if the ECM is broken and needs replacing, the scan tool will tell you.
so, there's no guessing or home remedies involved.
jeffreyhsmith
4G TL Problems & Fixes
Apr 4, 2018 03:37 PM
ton8383
Feb 12, 2016 03:42 PM
