Emission Light
Old Jul 28, 2020 | 10:29 PM
Jilet's Avatar
Emission Light
Hey guys, we have a 2013 acura tsx 2.4l.
116k miles
p0172 code
bank 1 too lean/too rich
Im thinking o2 sensor?
it was never changed and might want to do a tune up also, never did that also
Thoughts?
Old Jul 31, 2020 | 10:48 PM
EuroRspec's Avatar
116k miles
p0172 code
Thoughts?
Hows your gas mileage?
If you have a volt meter you can check to see if the o2 is working correctly. While the vehicle is running you should see the voltage fluctuating giving the ECU the proper measurements. If the voltage stays steady then you most likely have an issue. Otherwise, we are just guessing and throwing money at the problem.
Old Jul 31, 2020 | 11:36 PM
Jilet's Avatar
Gas mileage is fine not a big difference.
Just to add, when i stop at a light or traffic the idle would bounce up a bit here and there. It also gets rough sometimes also
Old Aug 1, 2020 | 10:28 AM
ScottyWM's Avatar
Bonehead
Spark plugs are recommended to be replaced at 100k, has that been done? Maybe a bad plug? It's an easy and relatively cheap item you can do yourself
Old Aug 1, 2020 | 10:41 AM
Jilet's Avatar
yes doing that soon i dotn believe it was ever changed.. waited too long
Old Aug 1, 2020 | 02:00 PM
Carpayment4life's Avatar
Here's what happend to me and may not be exactly what is happening at idle to you:
I changed my thermostat and thought that I had bled all of the air out.
When Idling, my tach would not stay steady. Instead, it would move between 800 rpm and 1500 rpm.
I bought a Lilse funnel
link link
and was able to get the air out and my idle became solid at 800 rpm.
peekay81
Oct 23, 2014 03:55 PM
kdawg8526
Mar 20, 2012 11:20 AM
huntingmark409
Integra
Jan 5, 2011 08:02 AM
Burghman81
Mar 2, 2009 04:34 AM
curls
1G TSX Problems & Fixes
37
Oct 22, 2006 11:52 AM
