Driver's side tire pressure
Old Mar 1, 2011 | 10:35 PM
Farage's Avatar
I have been meaning to post this for a while now. I like to keep my tire pressure on point due to handling and mpg reasons. Since this car has a useful pressure monitor (which overstates the psi), we can see the exact pressure in all the tires.
I have been noticing that both the front and rear driver's side tires deflate considerably faster than the passenger side. Around 4 psi each over the course of a month.
Anyone experience this and know the reason? Is it the extra weight of the driver?
Old Mar 1, 2011 | 10:51 PM
its rayden's Avatar
i hope you're checking your pressure at the same time in the morning, before your first drive, to compare your readings. your psi can go up as much as 4-5 psi just from driving it.
Old Mar 1, 2011 | 11:09 PM
ed_423's Avatar
SeeYou2Crew #2
^ that.
something similar happened to me, except it was only one wheel that was decreasing a bit faster than the other. got it checked out and turned out there was a nail in there.
Old Mar 1, 2011 | 11:12 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
4psi/month is high. Maybe you have a slow leak?
PyroDave's Avatar
i've got a nail in my back right one, but as of now its not leaking air(been in there a good 2 months atleast lol). after the roads improve a bit i'll have it repaired. tire coverage ftw
Old Mar 2, 2011 | 09:23 AM
Simba91102's Avatar
Old Guy
I agree. If you're losing 4 lbs a month, there's a problem (it is a good practice to check often, but..... it shouldn't really go down at all, even this time of year). It's odd that each one goes down by the same amount (right?). I have a problem with one of my wife's tires (it loses pressure intermittently, sometimes allot), I can't find anything in it, and I'm starting to suspect the TPMS valve stem unit. I wonder if these are going to start showing up as a problem?
Old Mar 2, 2011 | 04:42 PM
baltimorecaesar's Avatar
It's your fat ass creating more pressure in the tires on your drivers side, which accelerates the slow leaks you clearly have in your tires.
Old Mar 2, 2011 | 08:32 PM
Farage's Avatar
I'm pretty sure the tires don't have holes. And yes, I know to check the cold pressure. I don't believe its because of my weight, being that I only weigh around 170lbs. Still a mystery... Maybe it is the valve stems like simba said.
Old Mar 3, 2011 | 10:02 AM
pinatubo's Avatar
I don't recall that my tires ever have 4psi difference, 2, yes, but not 4.
They consistently show at 32
Old Mar 25, 2011 | 09:45 PM
SilverSVT's Avatar
How accurate are the monitors? I swear I sent my tires to 35 with a trusty gauge and not all show 35. Is there a reset procedure for them? On my Wife's Mini there was a button you had to hold down to "re-sync" after changing any pressure.
Old Mar 26, 2011 | 06:04 AM
TSXV6Guy's Avatar
Could also be leaking from the tire/rim interface due to corrosion. You can try spraying soapy water on the valve stem and other suspect areas to try to pinpoint the leak.
Old Apr 8, 2011 | 02:21 AM
ejongjin's Avatar
in the morning, in my parking lot,
the sunlight shine only right side.
when I turn on the engine, right side tires' air pressure is little bit
higher than left side,,,,
maybe this kinda related??
jblessing
Aug 8, 2018 09:43 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
gqdabien
Sep 8, 2015 11:41 PM
