Condensation in Headlights
Old Aug 12, 2015 | 10:18 AM
CybrRdr's Avatar
CBP TLX
My car was dirty so I took it to one of those high pressure no touch car washes. Now I notice that both of my headlights have water condensation inside the headlight.
I have read that a solution to get rid of the condensation is to remove them from the car and place them in a oven to bake. Is there an easier way to remove the condensation?
Old Aug 12, 2015 | 10:20 AM
<p>dont bake them to get rid of condensation....</p><p>&nbsp;</p><p>&nbsp;</p><p>the condensation should go away by itself, especailly in this Texas heat. it reached 106 degrees yesterday in Houston</p>
Old Aug 12, 2015 | 10:21 AM
ulrblitzer's Avatar
Could also try a heat gun if you're careful to melt/reseal .. but I would double check and make sure that's your true culprit and not a crack somewhere else.
Old Aug 12, 2015 | 02:57 PM
robpp's Avatar
Graphite Ghost
remove your drl bulbs while parked in sun all day to help speed up the process
or even a blo drier on low would go even faster.
Old Aug 12, 2015 | 03:02 PM
The baking method is usually done during headlight retrofits and people will put silica packets in to help with the condensation. Take off the bulbs as suggested and just park in the sun, it will go away on its own. Be careful with heatgun on the lens as you may burn/melt it.. (been there, done that trying to get condensation out..)
Old Aug 12, 2015 | 03:10 PM
<p>it's currently 99 degrees here in houston.<br />If that shit hasnt dried up, already....</p>
Old Aug 12, 2015 | 08:02 PM
Harper's Avatar
Unregistered Member
Words of advice, if you bake your headlamps in an oven you risk burning off the oem protection = they'll yellow sooner.
Old Aug 13, 2015 | 07:12 PM
CybrRdr's Avatar
CBP TLX
Thanks guys for the advice. Yeah it's been hot in Houston. I park the car out in the sun all day while at work. When I get to my car @ 5pm the temp reads 101 degrees but I still have condensation in both headlights. Maybe I need to remove the DRL's to speed up the evaporation.
Old Aug 14, 2015 | 06:40 AM
ceb's Avatar
ceb
Are you talking condensation or actual water droplets? If it is actual water AND your car is under warranty AND you have no headlight mods then go to the dealer.
If it is "only" condensation, then drive around for a half hour with your lights and high beams on to dry it up.
Old Aug 14, 2015 | 09:21 AM
CybrRdr's Avatar
CBP TLX
Headlights look foggy like a bathroom mirror after a shower. The whole headlight was affected but after a week of 100 degrees days , it is looks better. Only some condensation on the top of the headlights now. Btw, my TSX is 7 years old so no warranty.
Old Aug 14, 2015 | 09:26 AM
CybrRdr's Avatar
CBP TLX
Off topic question. I was planning to lightly buff and polish my headlights to make them look brighter/ clearer. Would that also remove the OEM protection?
Meguiars Headlight & Clear Plastic Restoration Kit, Meguiars G1900, headlight polish kit, restore yellow headlights, plastx polish kit, meguiars
Old Aug 14, 2015 | 09:53 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
<p>Yes</p>
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
