Check DRL System - iJDMtoy
Old 04-06-2013, 07:19 PM
rotciveel's Avatar
With the purchase of my leased 2010 TSX coming closer and closer I have begun the modification process of my car. I decided to start easy with the LED DRL kit from iJDMtoy. I figured it was a simply plug and play and after doing my research, I was confident I could get it done in 30 minutes. That was not the case...
I hooked up the stock harness to the decoder set to the resistors and bulbs just like the diagram they provide shows but the lights don't come on at all. Instead, I get the Check DRL System error in my dash. When I changed back to the stock bulbs, they wouldn't work and I got the error again.
--All of my other lights work, high beam does not. There is a sort of high pitch straining sound when I start my car that I did not notice before attempting this change. It also feels like the car takes more juice to start now? aka lights flicker longer before turning on.--
Any tips on what I could do to determine where the problem is coming from?
Old 04-06-2013, 09:54 PM
Graphite Ghost
robpp's Avatar
Do a reset by disconnect ing neg terminal and stepping on brake for a few seconds.
Once you get the code its a bit difficult to clear.
I can't remember but the dash puter may have had something to do with it.
So tell me about this kit exactly his did you hook it up.
I bought the resistors from JLC but should all be same.
Old 04-06-2013, 10:30 PM
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
Make sure you have your radio code before disconnecting!
Old 04-06-2013, 11:19 PM
rotciveel's Avatar
Is there anything else I need to be cautious of while trying the reset? I will try that tomorrow afternoon. Could it help make my lights work or just get rid of the error?
I'm using the following kit:
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r2.htm
Thanks for your responses, keep em coming!
Old 04-07-2013, 04:05 PM
2010 TSX
bagwell's Avatar
I basically have the same decoders but higher wattage bulbs and have had no issues...note -with those bulbs your high beams will be pretty much useless. I ordered some 50watt led but haven't rcvd yet.
http://www.ebay.com/itm/290872792673...84.m1439.l2649
Old 04-08-2013, 07:25 PM
rotciveel's Avatar
Alright, update!
I did not know but there were other fuses that are related to the DRLs. The right and left side high beam fuses. I checked these two and found that they were blown so I replaced these 10 amp fuses with a 10 and a 7.5 (I only had 1 spare of each) and now my stock DRL work!
I also talked to a JDM tech rep and was advised to change the polarity of the wires connecting the special harness to the stock one and the stock harness to resistor and bulbs, etc. I will try this out after I buy some more fuses in case I blow more. (I currently had black to red because this is how the clips were designed to snap snugly. I will try doing red to red and black to black.)
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
SpraykwoN
ILX
09-23-2015 11:44 AM
spiel08
09-07-2015 08:19 PM
Fadij
09-02-2015 08:31 PM
Quick Reply: Check DRL System - iJDMtoy
