Car Pulling Left
Old Apr 27, 2010 | 08:16 PM
james_and7's Avatar
Car Pulling Left
I noticed recently that my car pulls to the left very slightly. Not sure if this is because of the 245's I put on which are following the road a lot more or problem with the car. I noticed on the forum that there was a bulletin message about the TSX pulling left/right. Anyone have any input on this?
Old Apr 28, 2010 | 01:28 AM
09TSXTech's Avatar
James, there could be a number of reasons.
-Wider tires tends to track the groove of the road surface more, does this happen all the time or a particular section of road.
-Are your alignment OK?
-Tire pressure (left and right side the same)
-Tire manufacturing variance- one member with General Exclaim UHP tires that came from 2 different factories. The tires made in France are almost .25" taller than the 2 tires made in the Cezch Republic.
-Tire defective resulting in tire pull (that should be apparent immediately after you install the tires).
- If you have the stock tires/wheel, switch them back on (if it drive straight you can eliminate alignment issue).
Old Apr 28, 2010 | 01:30 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It could be your tire pressure, or your wheel alignment.
Old Apr 28, 2010 | 09:38 AM
james_and7's Avatar
I will check. Thanks for the feedback guys.
Old Apr 28, 2010 | 08:13 PM
the_razor's Avatar
i noticed that too and i have 245/40/18 however I did not experience that issue when i had my stock ones. either its my new tire size or alignment but highly doubt its the alignment. I agree with 09TSXTech for me it happens when i am at an intersection making a left turn and if i am not holding the steering firmly it turns left
Old Apr 28, 2010 | 08:37 PM
james_and7's Avatar
when i'm going straight and let go of the wheel, the car slowly leans to the left. I understand if its following the grooves of the road but it NEVER pulls to the right. tire pressure is all good. 35PSI. will have to wait until I put the stock ones back on to find out. can't bring it to the dealer with rims on b/c they will just blame it on that.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
