A/C not blowing cold air?!?!
Old May 28, 2014 | 08:58 AM
iSeeYouTwo's Avatar
Hey ladies, was in Atlantic City for the weekend... Man was that WILD! I experienced my first actual HOT day of the summer out there (88º F) & when I tried to use my A/C in AC (lol) it wouldn't blow cold air. I actually think the condenser or compressor wasn't even turning on. Checked fuse 16 and it was fine. Anything else I should check for?
Old Jun 2, 2014 | 07:59 AM
iSeeYouTwo's Avatar
Gee... thanks for all of the support guys! LOL
Old Jun 2, 2014 | 11:45 PM
3RDGENTL757's Avatar
Magnetic clutch relay for starters....swap it with another relay in the fuse box and see what's up...if it doesn't work after swapping then next step is to get some pressure gauges on it and check your freon levels
Old Jun 3, 2014 | 07:05 AM
rawger's Avatar
Lol at 88 being hot, well it is, but a week ago it was 96F over here. I always thought my AC was never up to par. I don't know if it's just hot as balls out here or what, but if I keep the AC at fan level 1 it's almost useless. 2 helps, 3 is the best.
Old Jun 3, 2014 | 01:11 PM
iSeeYouTwo's Avatar
Thanks for your input sir. I will try this today after work. Is it possible that the compressor isn't turning on because it is out of Freon?
Old Jun 9, 2014 | 09:53 AM
iSeeYouTwo's Avatar
Ended up just being low on refrigerant. Filled it up now it's blowing ice colddddddd
Old Jun 9, 2014 | 10:06 AM
rawger's Avatar
How did you find out? Did you go to Acura.
Old Jun 10, 2014 | 06:43 AM
iSeeYouTwo's Avatar
Nope. First I checked the relay like suggested above, and it was fine. I even switched it with a similar one and the compressor still didn't kick on. A/C fuse under the drivers side dash was good. So I asked my father who was a Master Tech for Honda back in our country (Dominican Republic) and he said on most cars, when they are low on refrigerant, the compressor does not turn on to avoid any possible damage. Guess it's some kind of safety feature.... but as soon as I added just a bit of refrigerant, the compressor fired right up.
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
