A/C evaporator drain plug??
Old Aug 18, 2009 | 02:21 PM
olimits7's Avatar
Question A/C evaporator drain plug??
Hi,
Does anyone know where the A/C evaporator drain plug is located on a 2009 Acura TSX??
I believe my A/C evaporator drain plug is clogged because I've noticed water leaking from my passenger side, and each time I turn I can hear a sloshing noise coming from behind the glove compartment.
Thank you,
olimits7
Old Aug 18, 2009 | 05:42 PM
olimits7's Avatar
Nevermind I found it and was able to fix the drain plug. The drain plug was right under the rug on the passenger side.
There were something blocking the drain pipe, but as soon as I cleared it the water started pouring out...all fixed!!!! :-)
Old Aug 2, 2011 | 07:11 PM
Gaukhell's Avatar
Im having same problem on 98 CL, is the evaporater drain in the same spot under the passenger rug?
Old Aug 4, 2011 | 02:28 PM
pinatubo's Avatar
Amazing that I have a very similar problem, not my TSX but home, the water poured down from the AC condenser and sipped through all the basement, all carpet had to be ripped since water all over the basement just to found out that the drain pipe connect between the condenser unit and the pump was clogged. Easy fix but carpet was gone.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
hashbrown
Sep 29, 2015 12:13 PM
