A/C evaporator drain plug??
Hi,
Does anyone know where the A/C evaporator drain plug is located on a 2009 Acura TSX??
I believe my A/C evaporator drain plug is clogged because I've noticed water leaking from my passenger side, and each time I turn I can hear a sloshing noise coming from behind the glove compartment.
Thank you,
olimits7
Thank you,
olimits7
Nevermind I found it and was able to fix the drain plug. The drain plug was right under the rug on the passenger side.
There were something blocking the drain pipe, but as soon as I cleared it the water started pouring out...all fixed!!!! :-)
Amazing that I have a very similar problem, not my TSX but home, the water poured down from the AC condenser and sipped through all the basement, all carpet had to be ripped since water all over the basement just to found out that the drain pipe connect between the condenser unit and the pump was clogged. Easy fix but carpet was gone.
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
