brake paddle release sound
Old Jan 4, 2012 | 08:30 PM
xyz2011basilisk's Avatar
I own a 2011 tsx, since the temperature started dropping, when I drive in the morning, I can hear some weird sound after I release the brake paddle (the sound is not from the paddle. It sounds like grinding, or some place lack of oil, I can't really describe the sound, but I've heard similar sound from other cars, e.g., Accord, Prius, Mercedes r), however, it only occurs in the first few stops, once the engine temperature raise up, the sound is disappeared, I'm not sure if this is normal in the winter, or I should have a check at local dealer?
Anybody else encountered similar issue?
Old Jan 7, 2012 | 12:16 PM
Haccord09's Avatar
I dont know the reason, but i have the same problem in my 2009
Old Oct 13, 2012 | 10:51 PM
tsxuser's Avatar
same here, since first day of ownership. Had dealer checked once, they said it will disappear around 10,000 miles.My car has 36,000 miles on it. still feel it. never trust stealership
Old Oct 13, 2012 | 11:09 PM
is it a transmission clunk?
video of sound or describe the sound
Old Oct 14, 2012 | 12:16 AM
iSeeYouTwo's Avatar
I don't think it has anything to do with the transmission if it's the same noise I'm experiencing. When I release the brake pedal slowly it makes somewhat of a grinding noise as if the pads or something is really dry and needs to be lubricated. I can't really explain it either, but i'll try to grab a sound clip tomorrow.
Old Oct 14, 2012 | 12:21 AM
benben01's Avatar
What you all are describing is perfectly normal. The best way to describe it is brake rotor resonance and it is temperature and brake pad material related. To make it go away for good, either change to a type of brake pads like a softer ceramic compound and/or new quality rotors like Brembo or DBA.
Feb 25, 2020 09:57 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:10 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
