Back Up Camera Goint Out
Old 06-11-2008 | 09:30 AM
Catman's Avatar
Tis is the second time this has happened to me, but my camera has gone out twice now. I shift into reverse and the mirror tilts down but no rearview camera. Both times that it has happened I put it in reverse several times with no camera. Later on or the next day everything is back to normal. Sounds like one of those problems that you can't reproduce and you can never get it to the dealer to show him the problem.
Old 06-11-2008 | 12:40 PM
ill45's Avatar
I've never had this problem on my TSX. I would take note on the situtations and specifics on when and how it occured then report it to the dealer. Maybe its just a loose connection or a wire somewhere. Good luck.
Old 06-12-2008 | 08:02 AM
LoveMyTL-S's Avatar
^ that is what I was thinking. Does the camera plug into the Navi unit in your trunk? Is so, check to make sure that connector is plugged in tightly.
Old 06-12-2008 | 10:47 AM
Catman's Avatar
I checked the connector in the trunk and it seemed to be fine. The first time it happened the car had been parked in the garage all night and I backed out of the garage, no camera....ran a couple of errands and everytime I came back to the car no camera.
The second time it happened, the car had set out all day in 90 degree heat. I left work went to the grocery store came out, no camera. Probably a broken wire or loose connection somewhere.
Old 06-12-2008 | 01:32 PM
Colin's Avatar
Does the camera not come on if you haven't hit 'ok' at the disclaimer screen?
Old 06-12-2008 | 02:35 PM
ill45's Avatar
It should... mine comes on every morning when i back out of my garage.
Old 06-12-2008 | 11:40 PM
RigaTony82's Avatar
It will still come on even if you haven't ok'd the disclaimer.
Old 06-13-2008 | 10:10 AM
Catman's Avatar
I always hit OK on my screen. I'm just hoping that it stops all together that way for sure it will be an easy fix for Acura.
Old 06-13-2008 | 03:40 PM
davidspalding's Avatar
Make a hole, coming thru!
What actually displays? Does the nav screen stay on a display, or go blank, or go white, or...?
OM (pp. 352-353) says you can adjust the brightness with the interface dial (while in Reverse), maybe that'd do something.
Old 06-14-2008 | 02:25 PM
Catman's Avatar
If I'm in audio or nav mod it just stays on nothing changes. Like I said it has only happened twice. It has only happened when the car is first started and then put into reverse.
Old 06-14-2008 | 10:54 PM
RigaTony82's Avatar
Same thing just happened to me today at work.
Old 08-15-2008 | 02:55 PM
PointQ's Avatar
got this yesterday at work. went to put the car in reverse.. right mirror tilted down, and nothing changed on the nav screen. turned the car off and back on, and it worked fine.
Old 08-15-2008 | 02:57 PM
MMsTSX's Avatar
JDM Addict
well, everybody having the issue should report it to their dealers.
then maybe you'll get a TSB about it.
Old 08-15-2008 | 03:19 PM
samwlee's Avatar
This just happened to me over the weekend as well. After a restart, it came back up.
Old 08-16-2008 | 11:00 AM
Catman's Avatar
MIne's been in for service but they couldn't find anything. I think it will be one of those things that they need to see it when it happens.
Old 08-20-2008 | 10:11 PM
PointQ's Avatar
happened to me again today. no strange weather or other conditions.. sunny day about 80 degrees. just wouldn't come on. restart fixed it.
rockyboy
08-04-2024 10:35 AM
Soul_Deamon
11-13-2018 04:44 PM
bymotion
11-18-2015 11:28 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
2015TLX
09-11-2015 02:56 PM
Quick Reply: Back Up Camera Goint Out
