Ac issue
Old Jan 19, 2016 | 09:36 PM
boki_cu2's Avatar
Ac issue
So my ac started blowing warmish air on drivers side and passanger is ice cold.
If i drive a bit and rev out drivers side will start to blow coldish but as soon as i stop its warm.
I run hvac diagnostics but not sure of codes for our car?
Can anyone help?
Video attaced of error code/s
Old Jan 20, 2016 | 12:26 AM
boki_cu2's Avatar
New development if my fan speed is on half i get cold air.....so air mixer?
Old Jan 20, 2016 | 11:14 AM
RTM's Avatar
RTM
I would suspect low charge of refrigerant.
When you aren't on half fan speed, where are you? If on high fan speed you get warm air, again, low refrigerant pops to mind. Low fan should get even cooler air.
If revving the engine gives you cold air, (you are moving the compressor faster), thus again, I think low refrigerant.
And I have no idea what that code means.
Old Jan 20, 2016 | 03:45 PM
boki_cu2's Avatar
If full speed fan drivers side dies down with cold air.
Once on half cool air starts comming thru as normal.
I hope someone can let me know what codes mean.
Old Jun 15, 2016 | 05:06 PM
amynrichie's Avatar
I know I'm coming into this conversation a few months short, but I am having a similar issue with my 2010 TSX. Blows cold air on the passenger side only. After doing some googling research, I believe it is the Air Mix Door Motor or the temperature actuator for driver side. In the dual climate controlled cars, there is a separate motor on the driver side and passenger side. It controls the level of hot and cold air mix. If one side stops working, then you will get cold or hot air from that side. Does this make sense? I'm trying to confirm what I think it could be on a common sense basis.
Old Jun 18, 2016 | 11:20 PM
rr5's Avatar
rr5
ac
I have 2009 tsx. Driver side vents blow warm air, passenger side cold. Problem was low refrigerant. After adding , no more problems. Freezing cold air on driver side.
nralpmet
56
Oct 11, 2019 12:34 PM
rcoz89117
4G TL Problems & Fixes
Sep 20, 2016 04:56 AM
Drudis
Jan 25, 2016 07:28 AM
gemz_acura
Jan 18, 2016 04:41 PM
02tlnate
Jan 17, 2016 12:05 PM
