2009 TSX Service Bulletins
Old May 5, 2010 | 09:43 PM
  #41
ed_423's Avatar
SeeYou2Crew #2
Originally Posted by nyydynasty
my 09 tsx (6 spd) is in for the brake issue right now. The shop foreman tried telling me that the bulletin is for the auto's only..........I just stared at him at that point because I didnt know how to respond to such a statement.
then he told me that the brake wear, which they notice is only on the rear brakes, is not because something is wrong with the car but because the car is heavier than the past models and smoother. Which means that drivers aren't aware how fast they're driving and have to hit the brakes harder, to slow/stop.
i'd just laugh and walk out of there and go somewhere else
Old Apr 16, 2011 | 12:04 PM
  #42
Principle's Avatar
Sorry I haven't really been keeping up with this stuff but no I don't have access to the whole list. I just got the numbers from google. They are correct and i had most of them done. If you have the numbers for the TSBs you can call the dealer and reference them directly then they will "magically" find them, otherwise call Acura from the dealer and let them talk directly to service. The dealer should not care because the service/warranty work is paid to them directly so they aren't ever out of pocket so to speak.
Old Apr 16, 2011 | 12:06 PM
  #43
Principle's Avatar
Originally Posted by cyberbro
Anyone know and/or had it done?
08-051 SEP 09 AcuraLink(R) - Control Unit Warranty
Exchange/Repair
My Acuralink has never worked even with 4 or 5 different phones I have had. Yes some of them had a data plan.
FYI this is supposedly a problem with the IPhone and a few others specifically. I say supposed because I have had IPhone since I bought the car and it worked then it stopped and the new ones worked intermittently.
Old Apr 23, 2011 | 10:54 AM
  #44
eta_vu's Avatar
Question
Hi all-
I'm a new Acura owner. I bought it used with 52,000 miles. Can I get these TSBs done on my car? Or does the warranty have to still be active as well as brought in by the original owner?
My front brakes are squealing and the original owner has already changed the rear brakes. Any info would be great, TIA for your help!
Old Apr 26, 2011 | 09:20 PM
  #45
5 Acuras's Avatar
Make it #7!
TSB 09-054: (2009-2010 TSX) Front Brakes Judder and/or Squeal
Dealer will replace front brakes at no charge on this TSB.
Service Bulletin 09-054
Applies To:
2009 TSX – ALL July 16, 2010
2010 TSX L4 – From VIN JH4CU2...AC000001 thru JH4CU2...AC018812
2010 TSX V6 – From VIN JH4CU4...AC000001 thru JH4CU4...AC002803
(Supersedes 09-054, dated March 17, 2010, to revise the information marked by the black bars)
REVISION SUMMARY
Under WARRANTY CLAIM INFORMATION, the flat
rate time was revised after the operation was reviewed
and validated.
SYMPTOM
When the brakes are applied normally, the driver feels
a juddering vibration through the steering wheel or
brake pedal, and/or hears a squealing noise.
CORRECTIVE ACTION
Refinish the front brake discs, and install new brake
pads with V-springs.
NOTE: If the vehicle already has V-springs and the
NS263H brake pads installed, this service bulletin does
not apply. Proceed with normal troubleshooting.
NS263H is the countermeasured
brake material for judder and noise.
PARTS INFORMATION
Front Brake Pad Set
(includes M77 paste, shims, and V-springs):
P/N 45022-TE0-999
TOOL INFORMATION
Brake Caliper Piston Compressor:
T/N 07AAE-SEPA101
The normal warranty applies.
Operation Number: 410820
Flat Rate Time: 0.9 hour
Failed Part: P/N 45022-SEA-J11
Defect Code: 07701
Symptom Code: 03503
Skill Level: Repair Technician
REPAIR PROCEDURE
1. Remove some brake fluid from the master cylinder.
2. Raise and support the vehicle.
3. Remove the front wheels.
© 2010 American Honda Motor Co., Inc. – All Rights Reserved BTB 43049-44463 (1007)
1 of 3
CLIENT INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment, and
training to correctly and safely maintain your vehicle. These procedures should not be attempted by "do-it-yourselfers," and you should not assume this
bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an authorized
Acura automobile dealer.
2 of 3 09-054
4. Remove the front brake hose mounting bolt.
5. Remove the brake caliper lower flange bolt, then
pivot the caliper up out of the way.
6. Remove the front brake pads, the shims, and the
retainers.
7. Check the brake disc thickness.
Maximum refinishing limit:
26.0 mm (1.02 in)
8. If the disc is within the service limit for refinishing,
refinish it with a Honda-approved commercially
available on-car brake lathe. If the disc is not within
the service limit, replace it.
9. Apply a thin coat of M-77 assembly paste to the
retainer mating surface of the caliper bracket.
10. Install the pad retainers, then wipe off any excess
assembly paste.
11. Mount the brake caliper piston compressor tool on
the caliper body.
12. Press in the piston with the compressor tool so the
caliper will fit over the brake pads. Make sure the
piston boot is in position to prevent damaging it
when pivoting the caliper down.
13. Apply a thin coat of M-77 assembly paste to the
pad side of the shim, and to the back of the brake
pads.
14. Install the new brake pads, shims, and V-springs.
FLANGE BOLT
CALIPER PIN
BRAKE HOSE MOUNTING BOLT
SHIM
SHIMS NEW
BRAKE
PADS
V-SPRINGS
WEAR
INDICATOR
09-054 3 of 3
15. Pivot the caliper down into position. Install the
flange bolt, and torque it while holding the caliper
pin with a wrench, being careful not to damage the
caliper pin boot.
16. Reinstall the brake hose mounting bolt.
17. Repeat steps 4 thru 16 for the other side.
18. Install the front wheels.
19. Lower the vehicle.
20. Press the brake pedal several times to make sure
the brakes work.
NOTE: Brake engagement may require a greater
pedal stroke immediately after the brake pads have
been replaced. Several applications of the brake
pedal will restore the normal brake pedal stroke.
21. Add brake fluid as needed.
22. Test-drive the vehicle, and check for judder or
squealing.
FLANGE BOLT
50 N.m (37 lb-ft)
CALIPER PIN
22 N.m (16 lb-ft)
Old Nov 3, 2011 | 03:27 PM
  #46
warped's Avatar
Unhappy Help!
I have a 2010 TSX with 25K miles. The front break pads "have 6mm left" and have "warped front rotors requiring replacement". I can't see the full TSB from Acura. The link isn't found anymore and the Acura TSB database is a fee-based site.
I was told that "this is considered normal wear and tear and not covered under warranty". I was confused by it all b/c I clearly wasn't grinding them with break pads (6mm should be okay) and it's not like I have a lot of miles or break aggressively. I probably down-shift more than I should, but I don't break more than I should. I was asked things like, "Do you break a lot? Or do you break quickly on the highway?" ...
I asked if this is a known problem and why it isn't under warranty. I was told it isn't common and it isn't covered because "breaks aren't under warranty". This now certainly sounds like BS.
They also told me my rear pads are at 3mm and the rotors need and can be resurfaced.
All this for only $1100 including my coupons.
Is there a remedy to this situation through Acura NA?
Applies To:
REVISION SUMMARY
and validated.
SYMPTOM
CORRECTIVE ACTION
PARTS INFORMATION
Front Brake Pad Set
P/N 45022-TE0-999
TOOL INFORMATION
T/N 07AAE-SEPA101
Defect Code: 07701
Symptom Code: 03503
REPAIR PROCEDURE
1 of 3
Old Nov 3, 2011 | 04:29 PM
  #47
5 Acuras's Avatar
Make it #7!
There's a link on here where you can get the TSB, if your car is covered under the TSB I would print it and bring it to the dealer. There was also a Class Action Suit for the rear brakes that entitles you to $150 rebate, not sure if it covers yours based on the VIN. Check out section 6 on this page: http://www.accordsettlement.com/
Don't let the Stealership get over on you.
Old Nov 9, 2011 | 12:17 PM
  #48
GBMTSX's Avatar
Originally Posted by 09TSXTech
^Welcome fellow Canuck to the forum.
Is your car Base/Premium or Tech model. Base/Premium comes with 7 speakers (no rear door speakers), the Tech model has ELS sound and 10 speakers (2 rear doors speakers).
Hmmm, I have a premium and didn't realize there weren't any speakers in the rear doors! I wonder if they are pre-wired and can be added?
Old Apr 25, 2012 | 03:21 PM
  #49
mR742's Avatar
While I do appreciate the posted TSB's including the ones at the top of the page; does anyone have access to the latest ones?
Old Jun 13, 2012 | 12:53 PM
  #50
rcktsientis99's Avatar
5th Gear
Anti-glare dash pad
Am I missing something here? Literally. That dash pad doesn't seem to do anything to prevent the glare on the display. I was given what appears to be the equivalent of a mouse pad. That's it. Is there something else that is supposed to go with the pad? IMO, the pad actually makes the problem worse. Acura should have replaced the display entirely with an anti glare unit. Does anyone else have the same issue?
Old Jun 13, 2012 | 01:46 PM
  #51
odus's Avatar
mine glares pretty bad i just accept it acura and many other dealers have a hard time doing alot of warranty work cause the company wants to ask them a million questions so unless something is really messed up i just accept it plus being first year for new body style doesnt help on the 09.
Old Jun 15, 2012 | 09:00 AM
  #52
iSeeYouTwo's Avatar
Do TSB's ever expire? How can I find out which are the latest, or the still active one's?
Old Apr 18, 2013 | 09:00 PM
  #53
JaredYng's Avatar
Can TSB's still be done after the factory warranty is up or does it need to be done before? i have about 1900 miles and a month and a half left. Is it wrong to print the list out and take it to them and ask them to do all that haven't been done?
Old May 9, 2013 | 07:55 AM
  #54
alpha2beta's Avatar
https://acurazine.com/forums/2g-tsx-2009-2014-143/updated-tsb-860643/
EE4Life
Nov 27, 2024 05:36 PM
TSX 09
2G TSX Problems & Fixes
Sep 23, 2015 08:25 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
atsx1313
Sep 22, 2015 09:04 PM
TSX 09
Sep 6, 2015 01:07 PM
