0W20 oil Recommendation
Old Jan 14, 2012 | 07:12 AM
gsvette's Avatar
What brand 0W20 motor oil are you TSX owners using?
I bought a 2012 TSX SE 6-spd. Just wondering what people are using or does it even matter (as manual says API certification Seal.
Thinking of using Mobil One synthetic. But I don't know if synthetic is going to offer any extra protection over non synthetic oil.
But if you go to the Mobil One sight and put in 2012 TSX it does not recommend
any oil instead it says not enough information for that particular vehicle!
Old Jan 14, 2012 | 07:19 AM
TSXV6Guy's Avatar
Particular brand doesn't really matter, as long as they are able and honest on certifying to API standard. Dealers almost always use bulk oil. I would go with a relatively known brand and appropriate certification. for 2012 TSX, honda recommends 0W20 so I would use that grade, regardless of brand. Note that some people think that you should not use synthetic too early in the life of the engine (unless it's factory filled with synthetic, which the TSX is not).
Old Jan 14, 2012 | 12:09 PM
kixo's Avatar
What is exactly changed in the engine between the 1st gen and 2nd gen TSX that it now requires 0w-20? 1st gen engines had 5w-20 as the recommended oil, and allowed use of 10w-30 if you lived in warmer climes.
I think even 09-10 TSXs were 5w-20.
Now it's only 0w-20 that is recommended. If this is purely so Acura can meet higher CAFE standards and not due to any manufacturing changes or tolerances, then wouldn't 5w-20 be okay and maybe even better for the engine in the long run?
I switched to 0w-20 Mobil 1 after about 5k of the factory fill for my 11 TSX MT. I am not even sure you can get pure dino of 0w-20; I think most available are synthetic or blends to achieve that level of viscosity.
Old Jan 15, 2012 | 07:07 PM
gsvette's Avatar
Kixo as you said the 0W20 oils seem to be synthetic.
I guess when it is time to change the oil I will go with Mobil one synthetic.
Old May 14, 2013 | 02:41 PM
marts230's Avatar
My independent repair dealer said that the only oil we can now use is mobil 1, and commented that most dealers only use bulk oil, the service techs generally do not know what is in the barrel.
Old May 14, 2013 | 02:45 PM
^dug up a year old thread just to repeat the same info over...
Old May 15, 2013 | 06:43 AM
musty hustla's Avatar
better than starting a new thread
Old May 15, 2013 | 07:05 AM
if it was a legitimate question or concern; then yes! it would be better than starting a new thread.
Old May 15, 2013 | 07:06 AM
Novichek's Avatar
According to this Penzoil Ultra (Quaker State UD) has a slight edge in additives package over mobil 1 and several others. All of the quality brands are fine though.
http://www.pqiamerica.com/March2013P...dpagefinl.html
Old May 15, 2013 | 07:15 AM
^thank you for contributing to the topic.
it doesnt really matter the oil used.
as long as you change the oil and filter regularly; your engine will be healthy.
Honda changed from 5w-30 to 0w-20 for CAFE reasons; in order to boost MPG through out their entire fleet.
Furthermore, most synthetics are blends of conventional oil. (I'm looking at you, mobil1)
Old May 15, 2013 | 07:21 AM
bagwell's Avatar
2010 TSX
yep, I'm sticking with 5w-20 in my 2010....Mobil 1 ain't #1 (or #2) anymore....
Old May 15, 2013 | 07:24 AM
bagwell, you live in Houston!?
meet up with us!!
your name cant be JEFF? can it?
Old May 15, 2013 | 07:38 AM
bagwell's Avatar
2010 TSX
meet up with us!!
nah, I'm not this guy --
But yes, I'm in far north crapston - I mean Houston.
BTW -- there's a $10 rebate on Pennzoil http://www.pennzoil.com/diy-rebate/
IBankMouse
Jun 13, 2020 12:53 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
