xtcnrice's bwp cu2
#361
Looks good, the brakes I need so bad
xtcnrice (07-21-2015)
#362
robpp pretty much nailed it in the head. Except, I got it rebuilt not using OEM Acura RL seals. I went with the Carlson ones, which are much cheaper (~$10 shipped per caliper).
Disc Brake Caliper Repair Kit Front Carlson 15385 Fits 05 12 Acura RL | eBay
Not sure where they're made from; perhaps China. But, I doubt they will give you any problems. Rebuilding is highly recommended if you get your calipers off a junkyard RL that's been sitting around for a while, or an RL that has a lot of miles. Otherwise, it won't be necessary.
I also went with 350z brembo rotors (12.8" diameter), along with EBC redstuffs. The EBC redstuffs squeal pretty often (not all the time), but I suspect this is due to brake dust. I've done the bedding process recommended by EBC and it didn't improve. I Googled it and many cars using the redstuffs have the same issue even after bedding, so it's not an RL conversion specific problem. I added brake quiet paste to the back of the pads (the shims) and the squealing went away for like 3 days, but came back. I suspect it only went away because I wiped off the brake dust from the shims, and after 3 days the build up was significant enough to squeal once in a while again. If you want quiet and not dusty brakes, I suggest going with RL OEM pads. I'm not sure which brand these are though. You can check with your dealer.
DD braking has improved. However, I wouldn't recommend these if you plan on tracking your vehicle (which from the sounds of it you are NOT), as the brake bias is worse than the OEM setup I believe. This whole brake bias business I believe is only relevant for mashing on the brakes as hard as you can (with ABS of course). With daily driving, braking will feel improved as robpp mentioned that there's greater pad area.
I don't know much about the TL-S brembos, except the following:
- requires TL-S knuckles as they are not plug-and-play with a simple bracket
- brake bias isn't great on these either if you plan on tracking, but should be slightly better than the RL setup
- much more expensive setup compared to the RL setup
- the 3G TL brembos are not exclusive to the 3G TL-S; the 04-06 3G TL dynamic (basically 6MT) comes with the same brembos as well, but Type S wasn't offered until 07+
What i prefer to do is to find the parts at a junk hard either for TLs or RL. And when i go, i assume i'm removing all of the braking components.
The following 4 users liked this post by xtcnrice:
#364
TSX AMG Type //M i-VVT
you kinda already gave it away by asking if you could fit a bumper inside the car lol
The following 3 users liked this post by iCrap:
xtcnrice (07-12-2015)
xtcnrice (07-13-2015)
#370
VTEC just kicked in, yo!
Sorry about the phone pics
DSLR wasn't with me but I couldn't pass up the chance to finally wash my car.
#becauseracecar #modulofront #justkidding
![xtcnrice's bwp cu2-h17i4ws.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/103031d1683154521t-xtcnrices-bwp-cu2-h17i4ws.jpg)
Little mod: blacked out 11+ foglight cover with V6 fog vents
![xtcnrice's bwp cu2-hmp7xi5.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/101967d1683154521t-xtcnrices-bwp-cu2-hmp7xi5.jpg)
![xtcnrice's bwp cu2-vklfe0b.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/103032d1683154521t-xtcnrices-bwp-cu2-vklfe0b.jpg)
Modulo rear
![xtcnrice's bwp cu2-fb1fved.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/102541d1683154521t-xtcnrices-bwp-cu2-fb1fved.jpg)
![xtcnrice's bwp cu2-lzjqyk2.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/103033d1683154521t-xtcnrices-bwp-cu2-lzjqyk2.jpg)
Obligatory BBK+wheel shot! Just noticed a spec of dirt on the skirt![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Modulo rear
![xtcnrice's bwp cu2-vporztq.jpg](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/102540d1683154521t-xtcnrices-bwp-cu2-vporztq.jpg)
The following 2 users liked this post by xtcnrice:
iSeeYouTwo (07-16-2015),
MC MiYoung3269 (07-17-2015)
#371
ROTAREDOM
Your front end needs something..
But I still love you
![Hug](https://acurazine.com/forums/images/smilies/hug.gif)
xtcnrice (07-16-2015)
#373
biter
#374
Confusing Name Guy
xtcnrice, might have missed it altogether but which bracket did you go with, fastbrakes? I'm a little concerned on rotor specs, I'm thinking of going with Stoptech (the Brembo 324x30 ones)
#375
Whyd you take off the front bumper?
#377
NAPA AUTO PARTS
They're "premium" grade NAPA rotors, but I have no idea what that means. They rust a lot more than my OEM rotors did
#379
Confusing Name Guy
I went with the FFC brackets, along with the 324x30 NAPA rotors for brembo-equipped 350z.
NAPA AUTO PARTS
especially at the rotor hat area. You might want to do some research on which rotors are better against rust if that bothers you. For the hat part, when I get a chance I'm going to wire wheel the rust off and caliper-paint it either black or silver. Any suggestions?
NAPA AUTO PARTS
As for rotors, Stoptech is generally known not to rust very much and is obviously a step above any general store rotors. I also think that EBC Ultimax rotors would be worth a look, and lots of people have used them with the RL calipers and EBC pads with great success. Plus you know that you're getting something that will work well with EBC pads which I believe you have
#380
Unregistered Member
#381
Confusing Name Guy
#382
Interesting. I've got the fastbrakes bracket and the fastbrakes instructions suggest Maxima rotors (12.6) from 06 - 11 (although up to 2014 works in reality), but multiple people have used the Brembo rotors with suggest, and in fact Heeltoe who sells the damn fastbrakes bracket suggest 350Z brembo brackets lol.
As for rotors, Stoptech is generally known not to rust very much and is obviously a step above any general store rotors. I also think that EBC Ultimax rotors would be worth a look, and lots of people have used them with the RL calipers and EBC pads with great success. Plus you know that you're getting something that will work well with EBC pads which I believe you have![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
But yeah I was on a bit of a budget. That and, there is a lot of conflicting information on whether the RL setup would fit the car or not (i.e., calipers not fitting over rotors, scratching noises during braking, etc), so I went with a setup that was at least tried and true for 1 particular individual (on honda-tech I believe). Besides the rust, I think these NAPA rotors are a great bang for the buck. Oh yeah, FFC site recommends 12.6" rotors (Maxima rotors or 350z non-brembo rotors). FFC recommends 12.8" rotors, but I'm pretty sure they could take the 12.6" ones as well. I've read more success stories with the 12.6" rotors, but if you want the big rotor look, then I say take the plunge and get the 12.8" from the get-go.
And yeah Harper linked a thread that has recently sparked some Stoptech controversy. I'm sure it's just a one-off issue and you'd be fine with Stoptech, but FWIW you should check out that thread if you get a chance
Let us (me) know of your progress if you decide to do the RL BBK!
#383
![](https://i.imgur.com/h17i4Ws.jpg)
![](https://i.imgur.com/hMp7xi5.jpg)
![](https://i.imgur.com/vKLFe0B.jpg)
Modulo rear
![](https://i.imgur.com/Fb1fvEd.jpg)
![](https://i.imgur.com/lZJQYK2.jpg)
![](https://i.imgur.com/VPorZTq.jpg)
Modulo rear
![](https://cimg6.ibsrv.net/gimg/acurazine.com-vbulletin/640x360/bf9_3479e63de2b20e61a478ece88b6e47d39fb29abc.gif)
Lol, but seriously, nice work. Your car is really looking good. Blacked out fogs is such a small mod, but looks much better IMO. Should probably go do mine and see how it looks.
Where did you get the open vents from?
The following 2 users liked this post by rawger:
MC MiYoung3269 (07-21-2015),
#384
![Snicker](https://acurazine.com/forums/images/smilies/emot-laugh.gif)
I use that gif literally on a weekly basis on whatsapp among other places
Appreciate the kind words sir! I was torn on whether I should do the dipped fog covers or not since I've been starting to accept the chrome infestation on my white car (it's not nearly as big of a contrast compared to seeing the chrome on a darker car imo). But I love it! Should've done it sooner. I think I said I'd do that on my very first post
The open vents are from the CU4 (V6 TSX). I literally got them from robpp (
#385
Ah, so you got lucky and got them off robb, nice. I looked through the website under bumper parts, but didn't really see anything for "vents". I don't know what else they would be called.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#386
009 71115-TL0-G50 GRILLE ASSY., R. SIDE (LOWER)
010 71116-TL0-G50 GRILLE ASSY., L. SIDE (LOWER)
V6 (vented ones):
009 71115-TL0-G60 GRILLE ASSY., R. SIDE (LOWER)
010 71116-TL0-G60 GRILLE ASSY., L. SIDE (LOWER)
They're $35 for each side
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
#388
#389
I'd like the front sport bumper, but they don't have it in NH788P. My paint code was introduced in 2012, and by then they stopped making the front sport bumper; only the rear. Acura instead uses the SE front lip as the front accessory since 2011. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I could get the front sport bumper and have it repainted... but that's a bit too much for me right now. Maybe some day... it's a nice bumper
#390
ROTAREDOM
Lmao I feel the same about the SE rear bumper. They don't make pwp! I want it though!
#391
^ I'd take that as a good excuse for a reason to get the whole car wrapped or repainted.
#392
I think someone was selling their PWP JDM Type S rear a while ago, but might have been sold. I think it was Prototype.
edit: nvm, he had the Type S side skirts (SE side skirts) in PWP: https://acurazine.com/forums/car-par...-parts-914999/
#393
It's available, just need to know where to look.
08P02-TL0-XXXXX
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#394
08P02-TL0-XXXXX
: Front Sports Bumper and Front Grille KitWhite Orchid Pearl (NH-788P) - Enhance the sporty looks of your car with the Front Sports Bumper and add that little bit of extra flair with the Front Sports Grille, to distinguish your car from others like it. As from 11.5Y must be combined - Includes: Front Sports Bumper 08P02-TL0-610C + Front Sports Grille 08F21-TL0-611A + Att. Kit including Fog Lights 08P02-TL0-600F (required even if car has STD fog lights)
08P02-TL0-XXXXX
#395
ROTAREDOM
#396
I put in a lot of effort to research & gain knowledge on things relevant to me. While I may be willing to share information, I will not share everything! The original poster can ask me for the part number. No guarantee I'll give it to him, because I believe he is capable of finding it himself. I gave him the lead already with what I've posted already.
#398
It is missing this lovely front grill should the front sports bumper proves to be inaccessible. I had pull this out of the box today for a stare & polish job, will use it one of these days. Need to paint the emblem backing plate to finish this project.
![](https://acurazine.com/forums/attachments/2g-tsx-photograph-gallery-144/30919d1437842502-xtcnrices-bwp-cu2-hpim1217.jpg)
#399
oohh i like that. where did you get it?
