Custom intake?
Old Apr 17, 2011 | 09:57 AM
  #81
Euronoob's Avatar
Just a quick question on how big the difference of the sound is :o I'll be waiting to hear more of your input about any gains or anything.
Also, are you furythree from OzHonda ^?
Old Apr 17, 2011 | 10:28 AM
  #82
ssjoeboe9's Avatar
ROTAREDOM
Yeah I was really surprised at the sound, it's been a while since I have had my resonator removed but if I were to compare sounds I would say it's pretty close to what it sounds like stock. And Yeah I am going to go for another drive this afternoon... It's really hard to gauge when something that used to be so auditory isn't there anymore. Plays tricks on you, so again I'll drive it and hopefully have a clearer analysis since I know what to expect. Plus it may take time for the ECU to completely adjust to more airflow.
Old Apr 18, 2011 | 02:26 AM
  #83
Euronoob's Avatar
Noob question: Can ALL intakes change from SRI to CAI? Or does it depend on which one you get etc etc? Because I'm a little confused about some people saying they change from SRI to CAI depending on the seasons.
A guy selling a Takeda intake was like to me $585 for long and $425 for short (SRI) and I didn't want to look like a noob so I didn't ask him.. So does he mean CAI when he says 'long'?
Thanks guys.
Old Apr 18, 2011 | 02:57 AM
  #84
ed_423's Avatar
SeeYou2Crew #2
Thanks guys.
not all intakes can do that. for example, the CT ice box can not. but intakes such as injen or takeda can change from SRI to CAI. so yes, it depends on which one you get
and i think the guy does mean CAI when he says "long". but the takeda should be able to change both ways...unless hes trying to screw u over by charging u extra for the long tube for CAI mode...
Old Apr 18, 2011 | 03:24 AM
  #85
Euronoob's Avatar
No clue.. All the text said was 'long intake or short? 425 was short ram.' So yeah... I think that's the cheapest I'm going to get here in Australia so might as well grab it. $425 AUD for a Takeda SRI and I can change it to CAI if I want right?
And thanks Ed. Thumbs up
Old Apr 18, 2011 | 02:35 PM
  #86
ed_423's Avatar
SeeYou2Crew #2
I am not 100% sure though, since they are charging you different prices for the cai and the sri. in the US, we just get the intake and it comes with both tube, one for sri, and one for cai. so i think you should either call and ask or find another shop.
good luck man!
Old Apr 18, 2011 | 05:45 PM
  #87
ssjoeboe9's Avatar
ROTAREDOM
So I have my final conclusion.... It has definitely made a difference. Of course the most noticeable is at Vtec. I would say it was an overall success. I would tell you how much I gained but you really think Ima pay for the dyno?? Fun mod, pretty easy and gained a couple horseys on the way. Happy modding
Old Apr 18, 2011 | 09:32 PM
  #88
Euronoob's Avatar
Ohh, so all it is is a 3" pipe just like yours and we're good to go? If so, I might give it a shot o-o
Old Apr 18, 2011 | 09:45 PM
  #89
ssjoeboe9's Avatar
ROTAREDOM
yup, dont know what the local hardware store is down under, but just fit some piping together and you are good to go. By the way, I used the rubber fitting that is attached to the resonator. Although it was slightly loose it hasn't caused any problems yet. If it does somehow slip off I'll just get some sealant and it should do the trick. Oh, and go ahead and by a K&N high flow filter....
Old Apr 18, 2011 | 10:44 PM
  #90
Euronoob's Avatar
Would it have any affect if I didn't have the K&N high flow filter?
Old Apr 18, 2011 | 10:54 PM
  #91
ssjoeboe9's Avatar
ROTAREDOM
Yeah you would most likely still feel gains. Just gives you a little more airflow with the cotton filter than the paper filter. hey, try it out, wont hurt anything!
Old Apr 19, 2011 | 03:19 AM
  #92
Euronoob's Avatar
Will do. How much did your PVC pipe cost? Because I don't even have a ROUGH idea of how much it'll cost lol.
Old Apr 19, 2011 | 08:47 AM
  #93
EdKiefer's Avatar
Alright, alright we have all been waiting and here it is.
Hard to get good photos with not much room to work with. Got to take it for a test drive. The only thing I noticed instantly was that it didn't sound as mean like when the resonator was removed. As far as feeling any gains, I am still unsure... hard to get past the sound at first. From 2nd gear rolling at about 15-20 mph I floored it and didn't feel much of a difference. But from rolling in 1st gear at about 10mph to flooring it I really felt a "little more kick" right towards the very end before shifting to 2nd and after shifting to 2nd it felt more dramatic than before. Still wanna drive some more before I give more info.
Don't take this wrong way but looking at last pic , your second pipe connection looks like it might be smaller diameter than the OEM downpipe to resonator . Did you measure that to make sure your not smaller .
you could not of made it all one size as the top, first section that the rubber coupler is on ?
Then have the 90 deg elbow on the outer diameter or they don't make them that size .
Old Apr 19, 2011 | 11:08 AM
  #94
ssjoeboe9's Avatar
ROTAREDOM
It was about $12 total including $4 for the paint lol.
EdK- It's all the same size, look at some of the older photos I posted before I put it on. They make couplars so that you can fit everything together without constricting your tube by inserting a smaller pipe. I mean how else would they do plumbing?
Old Apr 19, 2011 | 12:50 PM
  #95
EdKiefer's Avatar
Ahh, I see ,At first I thought the straight section was made up of 2 pieces , I see what your saying .
I guess the problem I am seeing is just the thickness and how PVC piping is available . To bad there not thinner walled stuff .
Old Apr 19, 2011 | 01:29 PM
  #96
ssjoeboe9's Avatar
ROTAREDOM
Yeah the wall thickness does kinda add to the overall bulk. But this was made more for fluid flow... and a lot of it at that. so thats why it's made that thick. Someone else made the comment about using rubber hosing, like the one that comes off of the throttle body. That would work as well but probably a lot harder to find.
Old Apr 20, 2011 | 10:17 PM
  #97
furythree's Avatar
Euronoob: yes im from ozhonda
ssjoe: im glad that it has made some difference!
do u have a higher res foto of that first post you made of the resonator diagram. did you really remove ALL of those parts u erased?
is the gain that u feel at low end or mid to high?
and have u confirmed whether the sound is quieter?
Old Apr 21, 2011 | 10:38 AM
  #98
ssjoeboe9's Avatar
ROTAREDOM
I kinda threw that picture together myself lol. But if you go to acurapartssuperstore.com they have almost every single part exploded and mapped out. pretty cool actually ( and they give prices next to each oem part and any acura dealership will match it; just a tip if some of guys happen to lose small parts while working on your car) As far as removing all of the parts, if you look it only like a total of 5 bolts. Once you remove the resonator they no longer serve a purpose. The gain is definitely at high end, its like vtec kicks that much harder. I'm not an overly agressive driver, but I won't go as far as saying I drive casually either, and it seems like I get to that 60mph so much faster than before. I look at the speedometer and see 60mph and frown that I already have to slow down haha. It def. sounded meaner with no resonator or anything, but louder isn't faster. And don't get me wrong, it's still louder than what it was originally...
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
