Ct-e icebox lid rubbing on hood....
Old 07-04-2015, 12:52 PM
I like cars.
Username 0's Avatar
Anyone else have this problem? The insulation under the hood is rubbing on the cf lid of the icebox causing it to damage the finish.
Old 07-04-2015, 09:28 PM
Jaheri_cbp's Avatar
The insulator rubs on a tiny spot of the piping on my AEM.. Thickest hood insulator I have had on any car if any. Really contemplating ripping that shit out its starting to look nasty
Old 07-05-2015, 12:46 AM
I like cars.
Username 0's Avatar
Yeah, it is pretty thick. I can see it crushing quite a bit on the cover when i close the hood. I thought about ripping it off or just getting rid of just that section but the car is still to new to me. Maybe ill just put some clear vinyl on the cf cover.
Old 07-05-2015, 08:54 PM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
PM Robpp. I think he had this issue and may have solved it.
Username 0 (07-05-2015)
Old 07-05-2015, 08:58 PM
I like cars.
Username 0's Avatar
K thanks
Old 07-06-2015, 09:19 AM
xtcnrice's Avatar
Np. Sorry if I'm wrong! Do let us know the solution if/when you do get one
Old 07-06-2015, 09:42 AM
Received 16,267 Likes on 11,974 Posts
lol at VERY minor issue.....
this is why God gave us Brains!!!!!!!!!!
you can either take off the insulation...or cut around the icebox...
and shut up Robpp.
Old 07-06-2015, 10:09 AM
I like cars.
Username 0's Avatar
Very minor issue, yes, but an annoying one that will eat at you whenever you drive the car. considering how much this intake is, this shouldn't be an issue and removing the hoods insulation or even cutting around it would be unaccepted since this is not a cheaply engineered intake.
Old 07-06-2015, 10:10 AM
I like cars.
Username 0's Avatar
and shut up Robpp.
Do you have the icebox installed in your cu2?
Old 07-06-2015, 10:15 AM
^its like you're not using your brain...
when you install something other than OEM, it WILL BE LESS RELIABLE. whether it be fitment or performance issues....
to solve your issue, simply remove the useless under hood insulation. no more rubbing. no more complaining. no more time wasted on how you can solve this issue.
Old 07-06-2015, 10:17 AM
when modding anything you need aptitude and the ability to think outside the box.
by thinking inside the box, you wont ever see why or how to solve things.
Harper (07-06-2015)
Old 07-06-2015, 10:25 AM
I like cars.
Username 0's Avatar
Must be a slow day for you at your bridge. Your acting like the Justin Timberlake of Japan.
Now run along be a cocky dick hole some where else.
This thread is for icebox users that can weigh in.
Old 07-06-2015, 10:30 AM
^so, are you not going to cut or remove the hood insulation?
Old 07-06-2015, 10:34 AM
rockstar143's Avatar
Received 20,015 Likes on 14,518 Posts
This thread is for anyone that wants to post in it. None of this is your intellectual property including threads you start. IB owns it. Shocking, I know.
Anyway, it's the truth, what is your goal? To find a "solution"? The solution is to put the stock intake back in since it was designed to work with the hood insulation and have perfect clearance. Although I do agree that when you pay a lot of money for a modification, you expect to not have to make any adjustments, that's often not the case. If you contact CT-E about a little chaffing you're getting...I'd be shocked if they don't reply with "where exactly are you chaffing, sir"?
The following 3 users liked this post by rockstar143:
04WDPSeDaN (07-06-2015), Harper (07-06-2015), justnspace (07-06-2015)
Old 07-06-2015, 10:37 AM
install stock intake to get rid of rubbing issues.
Old 07-06-2015, 10:43 AM
Jaheri_cbp's Avatar
Not neccessarily.. Our stock OEM akebono brakes suck major pinga, compared to even much cheaper, more readily available pad/rotor options. My China "Rock Auto" slotted and drilled pad/rotor special was still cheaper than OEM which I switched from due to the rear brakes practically being metal to metal at 19,000 miles. My car now has 100+k miles with the same "rockauto" rotors running strong, pads changed once more since then and crushes the OEM by leaps and bounds performance and longevity wise.
Old 07-06-2015, 10:44 AM
@pinga...
Jaheri_cbp (07-06-2015)
Old 07-06-2015, 10:45 AM
Also, interesting...my wife's old 8th gen accord had the rear inner pads metal on metal problem at 17K on the dot! On the 3rd swap I went with ceramics from autozone and it went a lot longer!
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Cut a hole in the insulation.
Old 07-06-2015, 10:46 AM
I like cars.
Username 0's Avatar
I never said this is my intellectual property. This thread is open to anyone, of course, but if you don't have this intake then well you are only speculating. I don't care who owns this thread, lol I just want to hear what other ICEBOX USERS have to say.
YES, I can remove the insulation or modify it. That's called common sense, not thinking outside the box. However, I will only do that if there are no other solutions or tips from OTHER ICEBOX USERS.
I have contacted ct-e, but in the meantime I would like to hear from other ICEBOX USERS.
Whats the point of putting stock parts into my car and posting here?? lol
Old 07-06-2015, 10:51 AM
Well, honestly, if the CT is touching the insulation, and someone figured out a way to make that stop happening, I'd be happy to hear it...just because it doesn't sound like there'd be another way.
I'm assuming there's no mounting bolt that would allow a little vertical play? Meaning you could unbolt and move the entire assembly down a smidge just so it doesn't touch? For us 3G guys, the heatsoak was so intense removing the insulation to allow better hot air venting under the hood was actually a great thing for us.
What's the finish on the CT box? CF with clear on it? I bet a hand buff with polish will bring the shine back...or maybe place some sort of sticker or even a clear furniture anti scratch pad there to kinda press the insulation up and off the box?
Just some ideas.
Old 07-06-2015, 11:01 AM
I like cars.
Username 0's Avatar
I just decided to remove the hood itself. Hows that for thinking outside the box?
Old 07-06-2015, 11:02 AM
Now you're just being an snide ahole.
I listed 2 possible solutions. I'm assuming your retort means you think they're not suitable?
So, you don't want discussion or solutions. You want a thread where only tsx owners with iceboxes that might or might not have this issue stroke each other off?
Old 07-06-2015, 11:32 AM
I like cars.
Username 0's Avatar
Ive already adjusted the box, ive already put clear protective film over the cover. My retort was out of contempt. Thanks for your solutions
Old 07-06-2015, 01:19 PM
Received 8,755 Likes on 6,752 Posts
KY jelly helps ridiculously well when it comes to chafing for me. Or if you want to go the organic route, virgin coconut oil does the job in a pinch and you smell like coconuts all day. Highly recommend both.
Old 07-06-2015, 01:54 PM
I like cars.
Username 0's Avatar
and this whole time ive been using the wrong personal lubrication. damn it.
Old 07-07-2015, 09:50 AM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
Did you get the SC yet?
Old 07-07-2015, 09:51 AM
What was the contempt for? I was actually trying to be nice and helpful.
At this point, I think this issue is bigger than the one you stated in your original post.
Old 07-07-2015, 09:56 AM
I like cars.
Username 0's Avatar
Not yet. Any day now.
Old 07-07-2015, 09:59 AM
the SC will work with the icebox?
Old 07-07-2015, 10:02 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Guys... you're starting to hurt my feelings.
Old 07-07-2015, 10:12 AM
xtcnrice's Avatar
Yeah both made by CTE. I believe Acura of Lynnwood promotes many of the CTE products, and they had a 2G TSX equipped with all of the CTE goodies, including the icebox and SC.
Old 07-07-2015, 12:48 PM
That's awesome...if I were to SC the TL, I'd go CT. I'd just pray it doesn't rub on anything.
Old 07-07-2015, 01:25 PM
xtcnrice's Avatar
CTE Icebox CAI, CTE catback exhaust, CTE SC
Those motor mounts tho..
Old 07-07-2015, 07:20 PM
ROTAREDOM
ssjoeboe9's Avatar
I still wanna find out how much my engine is moving. I think that might be my next video. Is the hood pretty easy to remove?
Old 07-07-2015, 08:50 PM
Yeah, 2 dampers and 4 bolts.
Old 07-08-2015, 12:26 AM
Jaheri_cbp's Avatar
No dampers.. Only on v6
Old 07-08-2015, 06:14 AM
Really? They dropped the dampers?! I guess that's good...one less thing to fail in 5 years.
Old 07-08-2015, 09:50 AM
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
I'm confused. Are we talking about the character Icebox or not?
Old 07-08-2015, 09:59 AM
Quick Reply: Ct-e icebox lid rubbing on hood....
