USB doesn't work anymore
Old Mar 10, 2011 | 09:04 PM
cricks11's Avatar
5th Gear
I've got a 2009 TSX without the NAVI, and I've been using a USB stick for music for about 2 years now without a problem. I didn't drive my car for a week, in which time it was really cold out, about minus 30-40 celcius. When I started my car again, my USB was no longer recognized. When I press AUX, it only goes to my bluetooth and does not switch to my aux input, and also the USB icon doesn't show up.
I've tested my USB on my computer and there's nothing wrong with it.
Anyone know what's wrong with it?
Thanks,
Alex
Old Mar 11, 2011 | 08:07 AM
saucy's Avatar
I know it is a pain in the ass, but may try disconnecting your battery to reset the cars computer. Yes this will reset everything from seat settings, radio presets and all but might fix the issue. Cars with all these features like computers it is just a matter of time before they need to be reset. Just a thought. Someone else chime in if there is another fix.
Old Mar 11, 2011 | 01:27 PM
TSXKid2010's Avatar
SEEYOU2CREW
Hmm that actually sounds reasonable. It also makes me think that Acura should have some kinda back up system for the car, like save all the presets on a USB or something.
Old Mar 11, 2011 | 01:55 PM
09TSXTech's Avatar
^Make sure you have the radio code handy beforehand.
Have you tried another USB flash drive? Although the stick works in your computer, it may be something else that prevents it from being read in your car. Process of elimination before disconnecting the car battery.
Old Mar 11, 2011 | 02:13 PM
pinatubo's Avatar
Are you sure you're using the same exact usb stick?
Old Mar 11, 2011 | 04:29 PM
cricks11's Avatar
5th Gear
yup it's the same exact stick. I also tried putting in another stick too and it doesn't work either. What's the radio code?? Security for the audio? Where would I get that?
Old Mar 11, 2011 | 05:53 PM
cricks11's Avatar
5th Gear
Thanks a lot! I managed to fix it!
Old Mar 11, 2011 | 07:35 PM
fjpthree's Avatar
how did you "fix it?"
Old Mar 11, 2011 | 09:12 PM
cricks11's Avatar
5th Gear
By doing just what saucy said. Reset my cars internal computer by disconnecting the battery and waited 15 minutes for the system to wipe it's memory clean.
Old Mar 12, 2011 | 01:46 AM
KinG of KonG's Avatar
I wonder why you would have to do that out of no where. Would love to know the cause of your issue so i know what to avoid. If Saucy is right its probably the one thing i will hate about all these feature intense is having to treat it like my computer.
Old Mar 12, 2011 | 01:50 AM
09TSXTech's Avatar
Where's the Ctrl-Alt-Del buttons
Old Mar 12, 2011 | 02:00 AM
cricks11's Avatar
5th Gear
The only thing I can think of is the cold. It was pretty cold when I started up my car and I never turn off my music :p. From now on I'm going to let my car warm up a bit before turning on the audio.
Old Mar 12, 2011 | 06:48 AM
TSXV6Guy's Avatar
^ My car was never affected by the cold... maybe your battery is getting weak and, after sitting in the cold for a week, the voltage drop when you started the car affected the various computers in the car? I would have the battery checked just to make sure...
Old Mar 12, 2011 | 08:38 AM
pinatubo's Avatar
I'm glad you got it fixed, m8.
Old Mar 14, 2011 | 09:52 AM
saucy's Avatar
Glad that worked for you. Dr. Reboot FTW!!! Ha, if only it were always that easy.....my car is smoking and making this really weird grinding noise. Disconnect/Reconnect battery, always works...
AndrewS
19
Mar 14, 2024 06:59 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
yahelou
Sep 6, 2015 09:12 PM
drewdeezy03
Sep 3, 2015 08:04 PM
