Iphone iOS4 wont work with Ipod Cord?
Old Jun 22, 2010 | 06:59 PM
dano9258's Avatar
I updated the Iphone to iOS4 yesterday and now it wont work on the AUX setting....any suggestions. Hard reset isn't working.
Old Jun 22, 2010 | 07:35 PM
Sev07ic_Sniper's Avatar
2010 TSX Owner
iOS 4 and my 2010 TSX
I'm guessing that the TSX's software does not support the newest OS because the iPhone OS info stated that it would have something to do with the connection between it and the car audio. I'm hoping Acura will address the problem, but then again I have a friend who tried to use his Zune in my car and it did not support that either.
Old Jun 22, 2010 | 07:43 PM
chilimost's Avatar
It's a known issue, unfortunately.
Until Apple fixes it (because Honda most definitely will not), a workaround is to reboot the phone, start the iPod app, *then* connect via USB.
This seems to be working so far for me.
Good Luck.
Old Jun 22, 2010 | 07:55 PM
run1down101's Avatar
6th Gear
After a phone power off and back on, mine was fine. Good luck...
Old Jun 22, 2010 | 09:47 PM
tsx_ridah10's Avatar
Havent tried it via the AUX cable but havent have any issues via USB. It works fine on IOS4!
Also music sounds way better on USB!
Old Jun 22, 2010 | 10:17 PM
DerwoodEE's Avatar
Mine works fine.
Old Jun 22, 2010 | 10:32 PM
2010 TSX Owner
Hey, thanks for the tip, I rebooted my iPhone and it works great now. Probably what everyone who is having problems should do.
Old Jun 25, 2010 | 04:01 AM
gsin's Avatar
7th Gear
works for me too... but sometimes i am unable to change track from the car audio controls, and it doens't even display the time of the track... donno if its iOS4 issue or what?
Old Jun 25, 2010 | 02:07 PM
Colin's Avatar
Looks like we have to cycle the ignition key through the accessory position and wait 10 seconds. Here are some notes from the engineer:
If the iPhone is (hard) reset, ACC OFF (for 10 seconds) and ACC ON, then the reset iPhone is connected, the system recognizes the iPhone.
Please note that if a non-reset iPhone (OS4) is once connected and disconnected, other iPhone(OS3)/iPod will not be able to be used until ACC OFF/ON with the vehicle.
Old Jun 25, 2010 | 09:38 PM
BlackMagicTSX's Avatar
New iphone 4 of course os 4 works with usb.
i havent tried aux yet. usb for iphone works for me 2010 tsx.
Old Jun 27, 2010 | 11:55 PM
Te_es_ex's Avatar
i updated to ios4 and am using the usb...it works..use the usb cord.
Old Jul 3, 2010 | 09:28 PM
lightjak_tsx's Avatar
mine works..
Old Jul 5, 2010 | 09:22 AM
dano9258's Avatar
Mine finally just started working again...i dont know what the issue was
Old Jul 24, 2010 | 04:36 PM
ZhenyaF's Avatar
Off roading in his
By any chance are you guys using a cable different then the one that came with the iPhone?
Up until yesterday I used a cable from an iPod and would have random problems accessing my music on my iphone/ yesterday I switched to the cable that came with my iPhone 4 and so far no problems.
Old Jul 26, 2010 | 06:53 AM
GrigioX's Avatar
he also has to make sure the iphone isn't outputting the sound via Bluetooth. I know in mine, if the bluetooth connects AFTER i've connected the usb cable, the iphone will default to bluetooth audio. I have to manually switch it back to dock connector. In this case, he would have to switch it back to earphones or whatever.
acurajj
Sep 19, 2015 03:47 PM
Barb Jackson
Sep 15, 2015 02:27 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
ivegotthenav
Sep 11, 2015 07:51 PM
IndycarFaster
Sep 11, 2015 02:52 PM
