Alright, installed the whole kit, everything looked good, drove around and came home to look at them not on. Ideas?? Pretty stumped here. I switched hem around and still no go.
Raw
Raw
Quote:
Raw
blew a fuse?Originally Posted by rawtsx
Alright, installed the whole kit, everything looked good, drove around and came home to look at them not on. Ideas?? Pretty stumped here. I switched hem around and still no go.Raw
2010 TSX
I had the same issue with my exled lic plate leds -- both were messed up and I blew 2 fuses trying to get them to work --- email the seller and he will have you return them for good ones.
musty hustla
close
- Join DateNov 2011
- LocationParts Unknown
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:101 Times in 88 Posts
Did you try the oem bulbs?
2010 TSX
Quote:
you need to replace the fuse in the driver's side interior fuse box....I believe its #27Originally Posted by rawtsx
What breaker is it to reset it?
I think there's spare fuses included in the under hood fuse box lid.
Ill have to check with a light to see if it's blown and what one it is. I jiggled the right one and it came on for a second...then nothing from either. Hoping I get it solved later today...last thing I need is to be harassed by the local cops.
Ok, for some reason they do work...but only when half way plugged in? Kinda seems wierd any one else have similar experiences? Seems like even a bump will set them off....
robpp
Graphite Ghost
close
- Join DateFeb 2012
- LocationHere
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:406 Times in 325 Posts
I assume you are still talking about the license plate.....
It should fit snug just like OEM.
I am sure exLED will replace it if something is wrong with it.
