Bluetooth Audio cuts in and out?? Anyone else have this problem?
Old Jul 25, 2011 | 03:14 AM
jvong's Avatar
4th Gear
I just bought a 2010 TSX, and I noticed that when I connect to my system via bluetooth audio to play music, the music would just cut in and out once or twice during my trips. Why is that? I own an iPhone 4 btw. Anybody else experience this problem and know a fix? Perhaps maybe the software needs an update (is that even possible)? Thanks yall!!!
Old Jul 25, 2011 | 08:49 PM
GBMTSX's Avatar
Is your iPhone 4 updated to its latest software/firmware or jailbroken? Have you tried using another phone to see if the problem persists?
Old Jul 26, 2011 | 05:15 AM
jvong's Avatar
4th Gear
yah my iphone is updated to the latest version, and not jailbroken. I'll have to test another bluetooth device to see if it does the same thing
Old Jan 23, 2012 | 09:56 PM
iamitman's Avatar
I am having this issue as well in 12 SE. Music just cuts out for few seconds and back. I am using HTC inspire.
Old Feb 6, 2012 | 12:40 AM
Chuckee's Avatar
Using a Galaxy S2. Choppy streaming with a bit of static.
My Galaxy Tab 10.1 works fine though. The only difference I can see is that the GS2 is Bluetooth 3.0 and the Tab is 2.1.
Maybe the Acura module doesn't talk well with the newer Bluetooth version 3.0?...
Old Feb 8, 2012 | 10:19 PM
VirusX39's Avatar
If you are streaming from pandora, I know there is an option if you hit the menu button and select preferences, there is an option "Cell Network Audio Quality" if it is on the HIGH setting it will be choppy unless you are on Wifi. I would recommend changing it to Normal.
(This is for the HTC Inspire, I believe there is a setting in the iPhone as well)
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
ivegotthenav
Sep 11, 2015 07:51 PM
siularbar
Sep 11, 2015 10:40 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
