Base system upgrade with balanced converter?
Old Jan 26, 2012 | 08:00 PM
wife's ride's Avatar
9th Gear
I have a 2010 TSX with the base "premium" audio system. I am soon to install a system with maybe three amps, one maybe two 10s, all of it kinda folded into the truck semi stealth.
I understand (thanks Mercman) that the base system has unpowered balanced signal coming from the HU to the amp. Also, that the amp doesn't have the controller of the 5.1. So bass, treble, balance, and fade are all handled in the HU. Correct?
So If I understand this right, I can use a balanced line converter in the trunk for each channel. I would then feed that output to the crossover.
I was about to start with the AudioControl LC8 downstream of the stock amp. But if this works, I'll wait and get the converter.
Old Jan 30, 2012 | 10:20 PM
9th Gear
No one has any idea?
Old Jan 30, 2012 | 10:23 PM
9th Gear
Maybe I should state that the LC8 is like the cleansweep. So it would have to go after the stock amp.
If I understand correctly, the head unit outputs a balanced signal, so a balanced line converter is what I need... right?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Sep 15, 2015 06:44 PM
alan_rich
Sep 7, 2015 11:08 PM
