Base 2011 TSX question
How does the iPod interface work on the base 2011 TSX? Does it display info on the radio? Can you control it with the steering wheels controls? Debating base model versus tech option. what would I give up by going with the base model?
7th Gear
If your Ipod has bluetooth it will stream audio wirelessly. You can control the ipod from the steering wheel controls but when stream I do not get the song information on the radio screen. I'm not sure if it works the same with the aux jack because I've only used bluetooth.
You don't really give up anything unless your goal is navi or a pretty screen. But if you know how to read road signs to get where you want to go, look up at the sky to get your weather information or look down the road in front of you to figure out whether there is a traffic jam then you don't need navi. As far as steering controls, I know mtripps said he can use his. I can't. I have a 2010 base model.
You should probably sit in one and play with the controls until you get comfortable with it and then sit in the other and decide what you want/like more in each. Good luck.
I Spit On You.
OP Tech package gives you: Navi, Back up camera, Better (IMO) sound system, Bigger and better screen (no one mentions this...), and 15gb's of storage for audio.
Soul_Deamon
11-13-2018 04:44 PM
