2012 TSX Bluetooth
You might also attempt waiting to connect initially until the engine is running. I leave my bluetooth off until the engine is started, then I wait for it to connect.
Solved all my glitchy issues regarding connection. Sometimes the HFL module doesn't seem to work and I have to turn it off then on again.
You should look around in the "Garage". Lots of good info in that thread. The link below could be found from it. You'll want to reference TSB 09-044.
https://acurazine.com/forums/second-...mation-789358/
