2nd Gen TSX TSB Information
Old 08-27-2010, 09:41 AM
csmeance's Avatar
Received 1,991 Likes on 1,414 Posts
TSB's:
Follow these instructions.
1. Open this link .
2. Select any entry to fill in the information for make, year, and model, then click on "submit vehicle information".
3. Open any of the listings.
4. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
2008:
TSB 08-017: 2009–2010 TSX: TQI of the DVD Navigation System With Voice Recognition
TSB 08-020: 2009 TSX: TQI and New Model Information
TSB 08-025: (2009-2010 TSX) Fuel Fill Door Is Hard to Open
TSB 08-027: (2009 TSX) Beverage Holder Lid Will Not Open
TSB 08-035: (2009-2010 TSX) DVD Read Error, or No Route Displayed, and Navigation DVD Is Scratched
TSB 08-036: 2009 Acura Paint Codes
TSB 08-040: (2009 TSX) Product Update: Valet Key Opens the Trunk
TSB 08-048: (2009 TSX) Audio or Navigation Display Unit Lens Reflection
TSB 08-050: (2009 TSX) Time on Display Changes Randomly
TSB 08-052: (2009 TSX) MIL Comes On With DTC P2422
TSB 08-058: (2009 TSX) XM Traffic/Weather and AcuraLink Messages Are Not Displayed, and Phone Number Features in the Navigation System Don’t Work
2009:
TSB 09-001: (2009 TSX) XM Notes Are Duplicated; Wrong Map Colors When Off-Route; Wrong Image Appears During Navigation Talk Button Tutorial; and Other Listed Symptoms
TSB 09-004: (2009 TSX) Subwoofer Rattles, Hums, and Sounds Distorted
TSB 09-005: (2009 TSX) Sounds From Speakers Are Distorted
TSB 09-008: (2009 TSX) All-Season Floor Mat Contacts the Clutch Pedal
TSB 09-010: (2009 TSX) Trunk Lid Hinge Makes Noise
TSB 09-014: (2009 TSX) Rear Shelf Clicks, Ticks, Creaks, or Pops
TSB 09-016: (2009 TSX) Windshield Side Trim Retainer Is Loose or Missing
TSB 09-019: (2009-2010 TSX) Popping or Clicking from the Left Rear or Right Rear Jack Point
TSB 09-020: 2010 TSX: TQI Information
TSB 09-023: (2009 TSX) Fuel Fill Door Detaches From the Body
TSB 09-035: 2010 Acura Paint Codes
TSB 09-041: (2009-2010 TSX) Engine Pings During Moderate to Heavy Acceleration
TSB 09-044: (2009 TSX) Intermittent No Sound From Audio Unit; Preset Buttons Do Not Respond
TSB 09-054: (2009-2010 TSX) Front Brakes Judder and/or Squeal
2010:
TSB 10-003: (2009-2010 TSX) Hood Vibrates or Flutters on Rough Roads or at Highway Speeds
TSB 10-008: (2009-2010 TSX) Retractable Master Key Does Not Lock in Its Extended Position
TSB 10-016: (2009-2010 TSX) Roof Molding Is Loose
TSB 10-017: (2009-2010 TSX) No XM Sound, But XM Station Information Is Displayed
TSB 10-018: (2009-2010 TSX) Paint Peels Off the Interior Door Grip Cover
TSB 10-024: (2009-2010 TSX) Engine Rattles at Cold Start-Up
TSB 10-028: 2011 Acura Paint Codes
TSB 10-036: (2009-2010 TSX) Front Grille Molding Is Peeling
TSB 10-043: (2010 TSX SEE TSB FOR VIN RANGE) Dashboard Is Bubbled
TSB 10-044: (2009-2010 TSX) Finish Peels Off the Parking Brake Lever
TSB 10-048: (2009-2010 TSX) 2009–10 TSX: Popping or Clicking When Turning the Steering Wheel
2011:
TSB 11-003: (2011 TSX) Product Update: Compass Displays Wrong Direction
TSB 11-008: (2009-2010 TSX) Front Grille Lower Molding Peels, Wrinkles, or Blisters
TSB 11-010: (2011 TSX) Navigation Display Intermittently Remains Blank After Starting
TSB 11-021: (2011 TSX) Products Update: Software Update to improve Fuel Injector and VTC Timing
TSB 11-022: (2009 TSX) Driver Power Seat is Rought or Bumpy when moving forward of back
TSB 11-026: (2012 TSX) 2012 TSX TQI Information
TSB 11-032: (2011-2012 MDX, 2011-2012 TSX, 2012 ZDX) Rear Entertainment Restarts when the ignition is cycled
2012:
TSB 12-008: 2013 Acura Paint Codes
TSB 12-011: (2011 RDX & 2010 TSX) Start Motor Intermittently Grinds in Cold Weather
TSB 12-014: (2009-2012 TSX) Console Armrest Is Loose
TSB 12-015: (2009-2010 TSX) Product Update: Roof Molding is Loose
TSB 12-018: (2009 TSX) Product Update: Windshield Side Trim Retainer is Loose
TSB 12-021: (2011-2012 TSX) HFL System Deletes Previously Paired Phone and Imported Phone Book
TSB 12-022: (2009-2011 TSX) Door Lock makes a high pitched whine or does not work
TSB 12-031: (2013 TSX) TQI Information
TSB 12-037: (2010-2012 TSX) Clicking Noise when turning the Steering Wheel
TSB 12-040: (2007-2011 TSX) Moonroof Glass Frame Rusts Under the Moonroof Seal
2013:
TSB 13-006: 2009–10 TSX: Sticking Rings Resulting in Unusually High Engine Oil Consumption (2009–10 TSX L4 with M/T )
TSB 13-010: XM Signal Intermittently Cuts Out or Poor Reception (2009-2010 TSX)
TSB 13-014: Safety Recall: 2004–08 TSX ECM/PCM Corrosion
csmeance is offline
The following 10 users liked this post by csmeance:
Anonymous99 (12-09-2015), bagwell (02-12-2013), gaTorSXtasy (05-08-2013), Mercedes>BMW (12-27-2012), mR742 (04-22-2012), ojasdatt (06-26-2012), Spikess (01-28-2014), TSX210 (05-06-2013), TSXV6Guy (12-15-2015), xtcnrice (09-01-2014) and 5 others liked this post. (Show less...)
Old 03-11-2014, 12:32 AM
csmeance's Avatar
bump, a few new TSB's added
csmeance is offline
The following 2 users liked this post by csmeance:
5 Acuras (05-03-2015), bagwell (03-11-2014)
EE4Life
04-01-2024 09:42 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
obert
09-03-2015 08:40 PM
Quick Reply: 2nd Gen TSX TSB Information
