Would 19x8.5 and 19x10 offset 37 all around fit on 2012 TSX?
I am wanting to buy a set of SSR wheels with 19x8.5 and 19x10 offset 37 all around fit on my 2012 Acura TSX without doing any fender work? What size tires would be good?
Will it fit? Sure.
Without doing any fender work? No.
Fronts probably wouldnt need much work, if any.
The rear will need to be rolled at the very least.
Really depends on how low you are dropped, if you're even dropped at all.
These rims coming off Lexus Is250 and the guy has his car drop pretty low with 235/35 front and 265/30 rear without and fender mods.
get 4 fronts and you should be good.
225 or maybe even 235 tires should be ok.
it also depends on how low you are..
if youre slammed, it prob wont work without some neg camber and some stretching.
as for the hub size, youre gonna need to either bore them or get adapters if theyre IS rims
my car is running 18x8 + 35 all around with 245/40/18s.
the fronts poke about a quarter inch while the rears sit perfectly flush.
10 in the rear is def gonna stick out.
8.5 in the front will stick out but not by much. maybe a little less than 1/4 inch depending on what size tires you run.
SeeYou2Crew #2
i don't think he needs to bore out the hub. they are SSR rims, that came from a lexus. not a lexus oem rim.
you most definitely can not compare both cars. lexus can run way more aggressive offset than us. the front should fit. rear can fit, but no way in hell in those tires.
235/35 should fit, the rear MIGHT fit depends on how low you are. you are most likely going to need at least -2.5 camber in the rear
you are going to need to roll your rear fenders, probably best to shave them and shave the bumper tabs while you are at it
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/wheel-tire-fitment-resources-821398/
See also:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/dropped-lowered-slammed-2g-tsx-pictures-details-reviews-872756/
Threads like this make my head explode
as for the SSR wheels you can probably fit the wheels in, but your rear tires will be to be replaced with a tire that is more stretched, most likely around 235. i checked the wheel calculator compared to my specs on how much room you will have, and you have like 1mm more then me but that still means you need a fender roll.
Thanks guys! I guess its better to go with 19x8.5 all around with 37-40 offset. 19x10 is too wide for my rear. I wish acura would make our body wider so we can put wider wheels on w/o shaving or mods!
Lexus is RWD vs the Acura being FWD. This may have to be looked at.
Never understood why people put such wide rims in the rear on a FWD car. Im a performance guy so thats why I dont understand. For looks I guess its cool, but for performance not a good idea from what Ive been told at the track.
Good luck tho. I hope it all works for ya!
