Weird sound? Needs advice
So I have a 2010 tsx lowered on tein ss coils. This morning while driving to work I notice a sound coming from my right side. Seems like I only hear it when I go over bumps. But I don't hear it on every bump. Cruising on a smooth street I won't hear it. I can't pin point where on the right side it's coming from. Any idea what it might be?
is it a knock or rubbing sound? front or back side? check for loose bushings and endlinks or bump stop like defcon stated. also check the top nut on ur shock/strut assembly, make sure its tight. ive heard of ppl not properly tightening that top nut.
very possible. youll need an allen wrench (dont remember the size. 8mm maybe) for the very top of the strut. hold that in place while tightening the nut. it would be no bueno if the shop/person who installed them did not do that.
Wierd thing is I drive home going 80mph and I didn't hear the sound. And I didn't hear it going over speed bumps . I'll have to remove my bumper it could be the ballast of the his fogs I installed.
Jgarcia looks like its a nut not a Allen wrench. You are talking about the nuts and bolts in the engine bay right?
https://acurazine.com/forums/showthr...&highlight=diy
looks like this was the culprit.
that gold nut in the middle was loose that i could turn it with my fingers. tightened the best i could and went for a drive and didnt hear the noise
SinCityTLX
20
10-19-2015 11:23 AM
