V6 or modded I4?
V6 or modded I4?
I saw a video of a bone stock V6 accelerating... I'm now debating if I should get a V6.
It doesn't seem like too many people on here have the V6, but does anyone know if they have common issues like the I4?
Also, say you were to do PCD and tune on the I4. Short of then adding on a supercharger you probably wouldn't have performance close to the V6, right?
Any issues with the V6? My I4 had the oil consumption issue and Acura rebuilt the motor. It's solid now, so I'd have my girlfriend take my current one and get myself a V6, because I'm just nice like that.
I believe the TSX J35 is along the lines of the rest of Honda's J35 variants .. usually hear the TL guys complain about pricey 100k timing service and PIA spark plug access on rear bank of the block. Kill some time in their section of the forum and see what's up. Also see that it's hard to squeeze out HP per mod. If nothing more, a modded V6 exhaust note is sexier than a 4 banger.
Side note, the J37's in the newer TL's also have oil consumption problems.
In regards to the timing service, is that about the tensioner that needs replaced?
Crazy thought:
Try driving the V6
There's no comparison in how much faster the V6 is. You'll need to boost the K24 or totally ruin the car's driveability to make the same power and torque as the V6. The V6 also makes power all the time. So you won't need to rev it up to get it going.
An 5 speed automatic 201hp naturally aspirated, 3400LB sedan is the most depressing thing I've ever heard of.
Try driving the V6
Crazy thought:
Try driving the V6
Try driving the V6
It seems like the timing belt issue everyone is having requires replacing the belt, pulley, tensioner and water pump... can you confirm and have you needed that?
That's the GVWR that's written on the door. Thats maximum weight. Curb weight plus max cargo.
Curb weight is what the car weighs. About 3400LB. Check acura's site or Edmunds.
I heaven't heard of that. The shop said it was just the alternator and that's all that was replaced, which fixed my problem. I had an awful whining sound when I accelerated.
+1 for the V6
You will not get the same satisfaction when you floor the pedal and feel the instant torque and throaty engine growl.
I have over 60k on mine and no issues other than regular maintenance (oil, brakes, battery and starter which was covered by Acura)
but good luck finding one because they are rare
<iframe width="560" height="315" src="https://www.youtube-nocookie.com/embed/Ui0YmSh7ux4" frameborder="0" allowfullscreen></iframe>
+1 for the V6
Do any of the accord or tl parts fit the tsx v6? Seems to be some exhaust components available, and it looks like at one point a dc sports cat back?
go V6!
I have had my 2010 TSX V6 Tech for 2.5 years now. Got it with 45000km and now have 81000km. V6 has better brakes and stronger front suspension parts if you are staying stock. V6 exhaust note is great when you stand on it.
Electric power steering was modified for 2010 V6 - has much better feel than I-4 cars I test drove.
Also nice factory rims if you are staying stock.
A bit more weight in front of course, but you only really notice if you try to throw it around - it will definitely push.
Fuel consumption on highway I consider very good for car its size. 7.2-7.5 L/100km at 110km/hr with cruise and A/C. City consumption not so great.
I tested I-4 with 6 speed and auto before I bought this one. Not nearly as nice to drive IMO.
Only issue I have had is the factory battery was becoming weak at 6 years old. Not unexpected. Replaced with 720 CCA battery from Walmart $110 CDN. Replaced original brakes - pads and rotors - at 80000km.
The timing belt service is unavoidable when you reach the interval. You have to expect to do the regular maintenance no matter what car you buy.
I'm not surprised.
You also have an S/C, which is I think more than I want to do. When it comes to making power you either have displacement or displacement replacement, but I think I'm going to go the displacement route.
This is mostly what I've heard. Better brakes, better suspension, better steering. The factory battery was the first thing I replaced on my I4.
What interval is the timing belt service and what does it entail? I see there is a gates kit for this.
T belt interval is 105K miles. IIRC, so is the timing chain interval, *technically*.
Buy the parts from Honda. There are plenty of dealer websites that sell parts at a discount. I use bernardiparts.com.
The gates kit is likely not the same as what you'd be buying from Honda.
It was the timing belt.
From all the input I've received, it seems like it's just the timing belt and components need replaced as a matter of routine care, rather than because they are faulty.
You know how forums are, you start going down one rabbit hole and every car is going to steal your girl and your lunch money.
A rabbit tried to steal my money once.
ONCE.
+1 for the V6
v6 owner here as well. I bought mine with around 38k miles on the odo. The car now has just under 100k miles. The only issue i have had was an alternator and the compliance bushings.
The car makes for an excellent daily driver. Plenty of overtaking power and tq down low. If you are looking at squeezing power out of it there is the ktuner for a tune, along with bolton's that the tl guys are doing: rv6 high flow cats.
I felt the stock suspension was way too soft. Very comfortable but very floaty also. A lot of the accord v6 parts will work on the tsx, I bought a buddy's coilovers from his accord v6 and they were a direct fit.
I feel the tsx is much quicker than my wife's 3.7 shawd TL. The auto seems to feel less sluggish, it very well could just be the curb weight difference or drive train loss on the AWD but I prefer the acceleration of the tsx v6.
I highly recommend the v6 if you can find a good one.
I was thinking if I could find a tech I'd want to check it out... I know there have been several complaints about the tech's blowing speakers, but I'm wondering at what listening levels those are at? I usually listen with my base around 18. I have the sub and bass turned up.
another thing you could consider is the TL has an optional AWD and with the TL you can have a manual I believe. Every time I see a TL at a show I think "dam I like that more than my car" haha thats just me tho
I don't mind the auto. Given the parts of the city I travel through every day my knee would hate me if I were to daily a manual.
