RDX 3.5 V6 (J35) - Modded
Old Feb 19, 2016 | 06:23 PM
chupp's Avatar
Hello,
I wanted to share with you guys the following:
I'm owner of RDX 3.5 2013 and I decided to start modding it a little bit ( mainly because this model is sharing the same base engine as the Accord V6/ TL ).
Performance mods:
  • K&N typhoon SRI ( 3.5" ) + air filter heat shield
  • ZDX (3.7L) Intake Manifold
  • ZDX (3.7L) Throttle Body
  • MDX spacer ( Intake manifold spacer )
  • P2R "thermal" intake manifold gasket
  • Custom JPipe ( 3rd cat deleted )
Future mods:
  • KTuner ( not available yet )
  • Replace my 3.5" SRI for a CAI. Worth it?
  • Stock size light crank pulley?
  • HFFCs ( For now, I prefer wait for a K-Tune )
The car is running great!!! The best mods were the MDX instake manifold spacer, the J37 IM/TB and the JPipe. The K&N SRI was my first addition and helped the throttle response but I would like to test someday a CAI setup ( to avoid heat soak ). After testing I've kept my stock IM cover vs the ZDX one ( in closed position for extra tq ) because of bad mpg.
Here some pics:
J37 IM / MDX IM spacer / P2R IM Thermal gasket:
J37 IM/TB / MDX IM spacer / K&N SRI:
Custom JPipe:
Summer setup on 20" Ruffino Chronos wheels:
Please comments feel free to comments!
Old Feb 19, 2016 | 07:05 PM
carbonTSEX's Avatar
The Original Shawdy
Thanks for posting here. This was needed. Curious to know what kind of gains you have received over factory. How much do you have invested if you don't mind posting. Also summer setup looks good!
Old Feb 19, 2016 | 08:19 PM
chupp's Avatar
K&N typhoon SRI ( 3.5" ): 200$ + air filter heat shield ( ebay 20$ )MDX spacer ( Intake manifold spacer ): less than 75$ with all new studs/boltsP2R "thermal" intake manifold gasket: 40$ZDX (3.7L) Intake Manifold & Throttle Body: 400$Custom JPipe ( 3rd cat deleted ): 400$
  • Best part! This mod really helped opened up the other mods ( ~12-15whp/10tq )! low end / mid range power increased significantly
At idle the car is still quiet and on wot the sound is really nice!
At this point I really need a tune to get the more of all theses mods and my project will be completed (except maybe a light pulley ~200$)! ( I will post dyno results sheets at this time! )
Note: I'm not trying to change the RDX into a beast machine just wanted to add more ponnies on an already great V6 engine/Tranny (6 AT) combo.
Old Feb 19, 2016 | 09:16 PM
carbonTSEX's Avatar
The Original Shawdy
Nice not the biggest investment. Hopefully ktuner pulls thru for you. I have my 2014 TL SH with CT icebox, xlr8 v2 Jpipe with 3rd cat delete, ATLP exhaust and have RV6 precat deletes to install soon. I also have the ktuner but haven't opened it yet as I'm waiting on the deletes install so I can get a custom tune. I bet it has some decent gains though on the RDX. Nice build. In for dyno results.
Old Feb 20, 2016 | 05:42 AM
Joe Las Vegas's Avatar
You want a real cold AI, keep it stock, it is set up to get air form the outside from both pipes, just put in a K&N drop in filter, cheaper and better off in the end. I did those so called CAI before on many cars and performance always got worse once the engine was hot and it was 70+ outside, even with heat shields in place, think about where the air comes from, just by looking at it, and if there are any openings to the engine bay, it will make it worse when hot.
Old Feb 20, 2016 | 05:50 AM
chupp's Avatar
Yes you are absolutely right. But the sound is so nice
Old Feb 20, 2016 | 06:01 AM
chupp's Avatar
Nice mods! I might remove the mid muffler for sound.
Old Feb 20, 2016 | 02:34 PM
banana13's Avatar
please do a video on the sound of your RDX and an instruction video on modding when you have time I'm curious.
Old Feb 27, 2016 | 06:31 AM
chupp's Avatar
Here some quick audio clips ( recorded with smartphone...):
  • RDXV6-InCabin-1.wav
  • RDXV6-InCabin-2.wav
File Type: wav
File Type: wav
Old Mar 17, 2016 | 10:44 AM
bluecarbonfiber's Avatar
WTF?
Has there been any update as to having ktuner help you unlock the ecu for more power?
Old May 1, 2016 | 07:24 AM
chupp's Avatar
Nah nothing yet! But my goal is to have my RDX custom tune this summer by an authorized ktuner dealer here in Montreal.
Old May 1, 2016 | 02:42 PM
chupp's Avatar
Latest mods
Latest mods:
  • Unorthodox lightweight crank pulley ( Stock size )
  • Replaced stock muffler with a Magnaflow
I just want to let you guy know that the light pulley worth every penny! Def. rev quicker!
The muffler replacement with the Magnaflow added a couple of ponnies and a sportier sound ( not loud, no drone ). I've done a road test on the highway without any muffler and it was terrible.
Old May 4, 2016 | 02:31 PM
AdidasCU's Avatar
5th Gear
Is there a difference between the ZDX and MDX 3.7L intake manifold and Throttle bodies? ZDX parts look much more expensive. There is much more used MDX stuff available. I have a 2015 RDX stock except for a K&N.
Old May 5, 2016 | 06:44 AM
chupp's Avatar
I believe theres no differences between the MDX and ZDX ( J37 ) intake manifold and throttle body. The TL SH-AWD ( J37 ) throttle body is a bit larger compare to the two other ones.
With both intake manifold ( MDX & ZDX ) you will be able to reuse your RDX IM top plate cover without any problem. If you buy the MDX or ZDX IM top pate you will gain more low end torque with the internal plate closed ( ~5lbs tq ) but will loose some high end power. I've tried this setup but my gas mileage have increased too much.
Old May 23, 2016 | 01:20 PM
me3's Avatar
me3
nice!!! Any plans for future mods?
Old May 30, 2016 | 09:52 PM
chupp's Avatar
Thanks!
Yep. I definitely need a tune to complete my project.
Old Aug 14, 2016 | 03:10 PM
chupp's Avatar
Just to let you guys know that KTuner is currently executing some tests on the 2nd Gen RDX ( 2013+ )!! Cannot wait!
Old Aug 14, 2016 | 03:15 PM
chupp's Avatar
Few weeks ago i've completed the throttle body coolant bypass mod. Quick and easy mod.
Old Aug 14, 2016 | 11:45 PM
dsyang112's Avatar
8th Gear
Originally Posted by chupp
Hello,
Performance mods:
Future mods:
Here some pics:
Custom JPipe:
Nice Mods! I'm about to get a 2013 RDX fwd and wondering if your mods would make the same effect on fwd and awd. Also, what's the gas mileage you have now after all these mods? If I don't want my gas go too bad, what's the best mods I should go for from your list? Thank you!
Old Aug 15, 2016 | 07:09 AM
chupp's Avatar
Thanks! I believe it should have the same effect on a fwd or awd model. The best bang for bucks as per me so far:
  1. JPipe with 3rd cat delete
  2. Lightweight crank pulley
  3. 3.7L (J37) Intake manifold + Throttle body
  4. MDX intake manifold spacer
  5. K&N SRI
Old Aug 15, 2016 | 09:01 PM
TheWrench116's Avatar
FLETCH
anyone run one of these at the track yet?
Old Aug 15, 2016 | 09:10 PM
RDX10's Avatar
That would be cool to see, but ken's RDX would eat these for lunch lol
Old Aug 16, 2016 | 01:08 PM
MTD's Avatar
MTD
Any dyno charts?
Old Aug 17, 2016 | 07:23 AM
chupp's Avatar
Originally Posted by MTD
Any dyno charts?
Not yet. I will get some once I get a tune.
Old Aug 17, 2016 | 11:05 AM
FLETCH
so would mine.
Old Aug 17, 2016 | 12:11 PM
RDX10's Avatar
so would mine.
Old Nov 26, 2016 | 07:28 PM
Tune done yet?
Old Aug 11, 2017 | 11:45 AM
FLETCH
Originally Posted by joe las vegas
tune done yet?
x2
Old Oct 30, 2017 | 11:15 AM
chupp's Avatar
Finally...
Received some info from Derek ( from Innovative Motorworks ). KTuner testing will finally be started on our RDX 2nd gen!
Old Nov 6, 2017 | 09:04 PM
Netforcer's Avatar
Finally...
Great news for sure!
Old Dec 27, 2017 | 02:59 PM
bfaucett's Avatar
Did you ever check with xlr8 or rv6 to see if their j pipes worked? Been a while since you posted, do you still have it and if so any updates?
Old Jan 29, 2018 | 01:37 AM
hlau415's Avatar
8th Gear
Thumbs up
Dang Chupp finally someone did some awesome damage to doing some dope stuff to their rdx!!! i will have to follow the leader on this mod. I have a 2014 rdx, I wouldn't think it is any different than 2013. Would it matter what year zdx you chose for the intake manifold and the throttle body? i just wanted to know before i dive into this mod.
Old Feb 15, 2018 | 07:11 PM
Charles26's Avatar
Hey
are you from montreal?
Old Feb 27, 2018 | 06:29 AM
NBPaspec's Avatar
any year ZDX or MDX 2010-2013 are the ones you want.
Old Apr 28, 2018 | 07:54 AM
Poolman's Avatar
Hmmm Chupp,,,what's up with all of this. Just thinking I need to do some wrenching and have parts available for such as this. Haven't seen an update on the goings on since November of last year,,,,is the vehicle still a rolling ?
Old Apr 29, 2018 | 05:27 PM
chupp's Avatar
My RDX is still running strong!
Bad news, Ktuner has still not release a tune for our RDX. It seems that their main focus is on the new Civic turbo platform...
My final and latest mod was a SprintBooster v3. I really like it. I made this decision based on a lot of reviews from the 4G TL & TLX guys.
Old May 28, 2018 | 07:33 AM
Tech's Avatar
Any dyno charts?
And those would only be of any value if they were taken before and after any mod and under the same temperature conditions. That tells you if any gains were actually made.
Old Jun 21, 2018 | 07:01 PM
JD8's Avatar
JD8
I just bought a 2014 AWD yesterday and will be shamelessly copying your build, starting with the custom jpipe. Did you get it done locally? Is it completely custom or a modified pipe from a different application like the TL or Accord?
Old Aug 1, 2018 | 04:24 PM
chupp's Avatar
No problem at all. Yeah i've custom made my JPipe by a very good local exhaust shop.
Like I previously said i'm really disappointed that Ktuner didn't release at least a stage 1 tune for our car even If we nearly have the same engine as found in the TL, Mdx and Accord. Ive been sending email for over a year (still in beta version ).
Overall I really like how my Rdx behave. With all.my mods and Sprintbooster it is really fun to drive. Great low/mid range power!
Please share your review/dyno once all setup!
Old Aug 1, 2018 | 10:50 PM
JD8's Avatar
JD8
Yeah, I was really hoping ktuner would come through for us. I'll start bugging them too.
Got the IM, TB and spacers bolted on this evening but I'm stuck getting the wiring harness to reach the TB since the wire is about an inch too short. May I ask how you got it to reach?
Thanks for the info on the jpipe. I'm thinking I might pick up an ATPL pipe for the 08-12 accord and have it modded to fit.
