precautionary question
Old Jul 9, 2011 | 11:30 AM
skyline8610's Avatar
so i will be switching my reverse lights to these leds :http://www.retrosolutionsllc.com/ser...T20-LED/Detail i was just wondering if switching from reg bulbs to leds while the car is in reverse will it short out anything? any help would be greatly appreciated thanks
Old Jul 9, 2011 | 11:41 AM
ressling's Avatar
to be ultra-safe you could disconnect the battery. Otherwise, just make sure all your lights are off and the car is off while you're replacing the bulbs. Replace bulbs one at a time and check to ensure that they work, but ultimately always replace bulbs in pairs.
Old Jul 9, 2011 | 11:51 AM
ok so il change one bulb with car off and test then change the other bullb and test. thanks
Old Jul 9, 2011 | 11:35 PM
its rayden's Avatar
why the hell would you change bulbs while your car is in reverse?
Old Jul 9, 2011 | 11:45 PM
Mr. NC's Avatar
You see me, I CU2
Engine off is the farthest I went in terms of "safety" when I changed my interior to LED and my reverse/turns
Old Jul 11, 2011 | 12:02 PM
mrstak's Avatar
7# werC 2uoYeeS
I changed all my interior with the lights and engine off. For my reverse ones, I changed the first one with the engine off but after I turned it on to test it to make sure it was working, I just left the engine on and switched it out. Nothing went wrong with my install so I guess I did okay.
Old Jul 11, 2011 | 02:37 PM
Honda_boy83's Avatar
You should have not problems, just have the lights off when changing!
Old Jul 11, 2011 | 03:22 PM
yup had car off then changed bulb and tested. i was just worried about shorting something out. btw if anyone will use these bulbs ul have to fold the connecters over to the opposite site thanks all
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
