LH Trans Mount Bolt - Special Socket Needed?
Is a special socket need to remove the bolt which holds the upper (cast aluminum) and lower halves of the LH trans mount together?
The 2009 TSX service manual states: Do Not Remove
Based on that I would assume there isn't a tool available to "service" the mount
Thanks. I just found it odd that the lower half of the mount is the same for both manual and automatic applications, but it's possible/likely there's a specific reason the two halves are to remain one unit.
jonnyj32
12-20-2015 11:36 PM
Carnie Hobo
11-27-2014 07:02 PM
