Ignition switch ?
Old Dec 26, 2015 | 12:30 PM
2012wagon's Avatar
Ignition switch ?
2012 tsx wagon
All stock
When I start it I hear a "bzzzzz" by the key area
It does it if I start it slowly
Battery is new in 2014 from dealer
No issues starting and no issues with car
A friend said his 2012 civic sedan does the same thing
Anyone else have it?
I don't know if it needs new ignition switch or a relay or starter is dying ?
My car is under full warranty and dealer is amazing
However usually they are bad at trouble shooting
Once I tell them what to change (thanks to this forum), they replace it
Appreciate the help
Old Dec 27, 2015 | 08:43 AM
blacktsxwagon's Avatar
Can you do a video? I'd be happy to help. We seem to have the same problems.
Old Dec 27, 2015 | 11:42 AM
2012wagon's Avatar
Yes I wil do a video in the next day or so and post it for you
Per my research lots of TL have this problem
Old Dec 27, 2015 | 10:15 PM
briq456's Avatar
2010 TSX does it to me sometimes too, my 05 Civic did it as well. Only when I don't turn as fast as normal. almost like a shorting out/buzzing sound.
Old Dec 28, 2015 | 10:09 AM
2012wagon's Avatar
Perfect description
Any fix to it ? Or let it be ?
Old Dec 28, 2015 | 10:23 AM
wrayman's Avatar
If you are describing the hum or buzz that activates when your key in position 2 ( just prior to turning over ) I believe this is normal.
My TL did it and my TSX does also. It stops after a couple seconds. I always wait and then turn the car over....might be the fuel pump setting up ? Not a mechanic, so not sure......
Old Dec 29, 2015 | 08:05 PM
atsx1313's Avatar
What he said....
I always turn to key position 2 (unless i am in hurry) and it always makes this noise... so I assumed it was normal...
I wish TSX has push button...
TSX69
3G RLX Problems & Fixes
42
Jan 15, 2025 03:54 PM
SSjTrunks112O
Jan 2, 2016 04:25 PM
Jessica Lyn
Dec 26, 2015 01:39 PM
4drviper
Dec 24, 2015 12:09 PM
Chris Jennings
Dec 21, 2015 05:45 PM
