Ignition switch ?
Ignition switch ?
2012 tsx wagon
All stock
When I start it I hear a "bzzzzz" by the key area
It does it if I start it slowly
Battery is new in 2014 from dealer
No issues starting and no issues with car
A friend said his 2012 civic sedan does the same thing
Anyone else have it?
I don't know if it needs new ignition switch or a relay or starter is dying ?
My car is under full warranty and dealer is amazing
However usually they are bad at trouble shooting
Once I tell them what to change (thanks to this forum), they replace it
Appreciate the help
All stock
Appreciate the help
If you are describing the hum or buzz that activates when your key in position 2 ( just prior to turning over ) I believe this is normal.
My TL did it and my TSX does also. It stops after a couple seconds. I always wait and then turn the car over....might be the fuel pump setting up ? Not a mechanic, so not sure......
My TL did it and my TSX does also. It stops after a couple seconds. I always wait and then turn the car over....might be the fuel pump setting up ? Not a mechanic, so not sure......![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I always turn to key position 2 (unless i am in hurry) and it always makes this noise... so I assumed it was normal...
I wish TSX has push button...
4drviper
12-24-2015 12:09 PM
