I think my 2009 TSX just bit the dust but we shall find out what failed tomorrow
Mileage: 618xx
Car: TSX 2009 5A Tech
Conditions: Hot 90F+ weather, AC on full. Driving on city streets (normal traffic).
Well I am not sure what happened. On the way home from work it was running fine , the last mile or so the engine RPM kept bouncing off the low point (stalling) at idle (at the lights) I had the AC on so when I got closer to home I turned that off. As I was pulling into my underground parking lot (two sets of gates, one main and one garage gate), I noticed it was doing that even more, so i turned off the music but then heard a loud screeching noise and I thought i didnt turn off the music but it was off and then I saw smoke. Called the dealer right away, he asked me to start it up and withing 5 seconds it screeched with smoke. Its got coolant in it and its been maintained. It made some sort of a hissing sound. I couldnt tell exactly where the smoke was coming from but it was somewhere in the back area. The front stabilizer bar has smoke like 'steam dust' on it.
A neighbour helped me push it into my spot. Its being towed to the dealer tomorrow.
Its done the low RPM thing once before, a few months back. I was driving to work, approached a light under braking, the RPM's dropped it almost stalled and then bounced back up..
So the question is. Should I dump it for a 2011? Or go something else/ I've had loads of trouble with my 2009.. ugh!
Ive had a 2009...well since 2009 have about 46000 on the clock and only problems i had were the brakes and the speakers, both replaced with aftermarket at about 20k havent had a problem since
I guess I am the trail blazing person here, with 61K miles on it. I do remember being the first one to complain about the brakes at 13K.
So who knows if the 2009 has issues that I am seeing before you guys. By the way keep an eye on teh transmission fluid, i had to change mine 3x at 35K.
You probably just got unlucky with your tsx. I think someone said once that out of production, 6/10 of tsxs are normal, 2/10 better than normal, 2/10 worse than normal. Something like that.
i am 70 city/30 freeway with 27K miles with original brake pads. no transmission fluid change. and i highly doubt ur TSX has seen this.
it's a car-drive it
I think the lemon law no longer can be used. There are certain rules that have to be followed. I think 3 times with the same problem (safety related, not rattles, squeaks, etc) within a certain period (the first 18 months) and the dealer has to be able to try to fix it.
Well it took a long time of idling before the problem showed up at the dealership. I think once the ambient air temp came up, the problem manifested itself.
They said the AC relay was not working but also that there is a problem with the pressure building in the AC system until it released pressure out of the emergency valve or something.
They have to evacuate the whole system and rebuild it after replacing a few valves.
There are no IAC and vacuum problems, it was the AC compressor adding extra strain on the engine at idle that was making it bounce and almost die at idle.
They estimate about 450 to fix it.
This morning it was clicking on and off normally at the dealer until I was there, it blew its top after I left for work.
as others mentioned it seems like the issue is not as severe as initially suspected, so cheers to that.
FWIW, I have an '09 w/ 19k on the odometer and have yet to have a single issue. I think I've invested all of about $200 in maintenance costs into my ride
Great to hear the problem is not fatal. Agreed with other readers, talk to the service advisor or contact the local Acura rep and try to have that repair under goodwill.
FWIW, my car has 54K miles and no problem with the A/C.
cycdaniel
12-17-2019 10:58 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
